HMG 3.0.37
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
A little more for .37a:
I've modified build.bat and hmg.hbc to support two parameters:
/n: No run after build.
/d: debug
They are mutually exclusive.
I've tried to keep, well docummented, simple and easy to maintain.
Besides that, I've updated IDE to support debugger again.
All is attached to this message.
Please, report any problem.
TIA.
/d: debug
TIA.
- ide.zip
- (801.65 KiB) Downloaded 293 times
Re: HMG 3.0.37
Great Roberto!
Mario Mansilla
Re: HMG 3.0.37
Hola :
La ultima versión del IDE no me graba las modificaciones de la propiedad Caseconvert cuando el datatype es caracter .
Saludos .
Mario Mansilla
Hi
The latest version of the IDE did not record changes to the Caseconvert property when the datatype is character.
Greetings.
Mario Mansilla
Saludos .
Mario Mansilla
Hi
Greetings.
Mario Mansilla
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
IDE again...
Two little fixes including the one reported by Mario mansilla.
- ide.2011.06.23.zip
- (937.52 KiB) Downloaded 307 times
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
A new build.bat / hmg.hbc combo, supporting /c (console mode) parameter.
- another_build.zip
- (1.72 KiB) Downloaded 261 times
Re: HMG 3.0.37
Thank you Roberto.
Shall we release the updated version?
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
I have one more update/fix for the IDE/build.bat/hmg.hbc combo.rathinagiri wrote:Thank you Roberto.
Is attached to this message.
Please, test it and if all goes fine, I guess that we are ready for a new release.
Remember to delete the files hmg.ini and editor.ini in /IDE folder, so they wiil be correctly created when the IDE run from the first time.
TIA.
- ide_and_build_20110624.zip
- (797.91 KiB) Downloaded 333 times
- MigSoft
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
Re: HMG 3.0.37
Hello,
Attached file code highlighter for Notepad++
MigSoft
MigSoft
- For Notepad++.zip
- file code highlighter for Notepad++
- (4.44 KiB) Downloaded 333 times
- For Context.zip
- file code highlighter for Context
- (5.29 KiB) Downloaded 286 times
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
Thanks!MigSoft wrote:Hello,
MigSoft
Re: HMG 3.0.37
That's great MigSoft. Thanks a lot.
