HMG 3.0.37 (Old)
HMG 3.0.37 (Old)
I have uploaded the latest version 3.0.37.
You can download HMG 3.0.37 from here. (31 MB)
Please test and give your opinion.
Re: HMG 3.0.37
Great work!
I'm starting to test it!
Best regards, Marek
Best regards, Marek
Re: HMG 3.0.37
first:
1. IDE has no "Reset project incremental data" option
2. There is no debugger!!!
3. I think, IDE hmg 3.0.37 is not portable - it takes harbour from c:\hmg not from directore, where hmg.3.0.37 is placed
Re: HMG 3.0.37
Can you please tell which file makes it not portable?I think, IDE hmg 3.0.37 is not portable - it takes harbour from c:\hmg not from directore, where hmg.3.0.37 is placed
Or, What is the content of your newly installed IDE folder's hmg.ini?
Re: HMG 3.0.37
UPS... I've installed HMG.3.0.37 to c:\hmg and renamed it to hmg_3_0_37 after.
I dind't change anything in hmg.ini
My fault, sorry.
Marek
My fault, sorry.
Marek
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
Simply deleting hmg.ini, it will be re-created, containing the correct hmg root folder.mol wrote:UPS... I've installed HMG.3.0.37 to c:\hmg and renamed it to hmg_3_0_37 after.
My fault, sorry.
Marek
Re: HMG 3.0.37
and what about reset incremental data?
My program was compiled with new hmg and crashed with error:
I think that some modules stay compiled with old version
Date:11.06.20 Time: 14:23:12
Error: HMG 3.0.35 (2010.06.20)
Control: T_KlientNazwa Of OknoRejestrFZT Not defined. Program Terminated
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
This is an experimental build!!!!!mol wrote:first:
To reset project incremental data, you simple must to delete the .hbmk folder in this project!!!!
Re: HMG 3.0.37
I was deleted it...
I found that HMGVersion function returns "3.0.35"
file:
c:\hmg\source\h_error.prg
file:
- Roberto Lopez
- HMG Founder
Re: HMG 3.0.37
Ok.rathinagiri wrote:Hi,
Some little things...
1. 'hmgver.dat' files are not longer used. Please delete.
2. Please, add the mixed mode sample I've posted to samples. It will address the issue 'how to create a mixed/console app with the new build?'.
3. The file hmgc.hbc is no longer needed. You can delete it.
4. Correct hmgversion() function to indicate the true version.
5. I've dropped PSPAD. I've changed to Notepad++. It is fully free and freely redistributable. It is (IMHO) superior to PSPAD and its style is more 'inline' with IDE style. Please, test it. If you agree with my opinion, please, change PSPAD for Notepad++.
6. Buildlib.bat point to \hmg, so it will not work with default install location. Please, use the same technique as in build.bat.
That's all!
