HMG 4 All-in-one Demo
Hi all,
Mauricio Ventura Faria has created a Demo with HMG 4 having all the controls in one place (like the main.demo of HMG3). You can download the demo from here and it contains everything needed to run: EXE, PRG, QT DLLs, icons, etc., no need to install anything, just unpack and run.
demo_hmg_4.zip (6.8 MB)
concentra
Re: HMG 4 All-in-one Demo
Post by concentra »
Rathinagiri, there is a problem with this ZIP.
When decompressed, it generates a file called demo_hmg_4 without extension, which is in fact another ZIP.
Could you please revise this ?
[[]] Mauricio Ventura Faria
Is it? I will check and change. Sorry for the inconvenience.
For me it is working fine. Somebody else having the same problem?
concentra
Post by concentra »
Rathinagiri, I only noted this because someone else in another forum said to me.
I downloaded it to a new, fresh installed Windows 7 and when I try to open it I receive the following:
Compressed (zipped) Folder Error
Windows cannot open the folder.
The Compressed (zipped) Folder 'demo_hmg_4.zip' is invalid.
tuve el mismo problema, en vez de abrirlo lo guarde y despues descomprimi.
no funciono el demo. el mismo se ve en el tray pero al posicionar el mouse el mismo desaparece.
no puedo compilar ya que me falta algo en HMG.4
creo que es necesario una instalacion completa de HMG.4, mejor dicho un nuevo BUILD de HMG.4
actualizado al 15-07-2011
Translate Google
I had the same problem, rather than keep it open and then decompressed.
The demo did not work.t is in the tray but at the same position the mouse disappears.
I can not compile and I'm missing something HMG.4
I think you need a full installation of HMG.4, rather a new build of HMG.4
updated at 15/07/2011
[img]tray.jpg[/img]
Jairo Maia
Post by Jairo Maia »
Hi Daniel,
I see that you are using the Avast antivirus. Disable the Avast for 10 minutes e.g., and try again. The Demo will be run properly. There a problem with the Avast and this demo.
I talked to Mauricio about it, and he answered that is updating the demo.
Jairo
exactamente es asi, no funciona con Avast Antivirus, el Demo funciona correctamente. muchas gracias por el dato Jairo
exactly so, does not work with Avast Antivirus, the demo is working properly. thank you very much for the tip Jairo.
concentra
Post by concentra »
Hi Jairo.
Jairo Maia wrote: Avast antivirus
Could you inspect the Avast log and post any message Avast produces when blocking the file ?
In Windows 7 Avast seems not to be the problem, if I run the demo in Windows 7 with Avast activated, it shows the message "demo_1.exe has stopped working" and options to close the program.
Weird enough, if I run the demo 3 or 4 times it starts !!!!! :evil:
In my Windows Vista Ultimate also, I encounter the same problem. I don't have Avast anti virus.
