Hi Rathinagiri:
Rathi phenomenal: rename my settings, copy a new hbmk.hbm within my application folder. included in the ide lib hbmzip.hbc because that gave me an error again.
although not included in my project.
The application compiles perfect!!
Thanks for your work.
Fenomenal RATHI: rename mis configuraciones, copie un nuevo
hbmk.hbm dentro de la carpeta de mi aplicacion. en el ide inclui
hbmzip.hbc ya que esa lib me dio de nuevo un error.
a pesar que no esta incluida dentro de mi proyecto.
la Aplicacion compila perfecto!!!!
Gracias por tu trabajo.
Saludos/Regards
HMG 3.0.36 (2011-05-31)
Re: HMG 3.0.36 (2011-05-31)
- vencimientos.jpg (27.33 KiB) Viewed 4439 times
Kindly save this code as build.bat in c:\hmg folder. Now you can use IDE in the new version. For console mode, still I could not compile using IDE. However, it can be compiled using build.bat in command prompt with /cr switch.
Kindly test and tell me your opinion. If everything goes ok, we can remove 'test' in the name!
@echo off
cls
rem ***************************************************************************
rem HMG 3.0 Build batch
rem Roberto Lopez (2009.10.22)
rem Set variables
set AppHmgVer=""
Set HmgPath=%~dp0
set /p HmgVer=<%HmgPath%\version.txt
echo %hmgver%
if exist hmgver.dat set /p AppHmgVer=<hmgver.dat
echo %AppHmgVer%
Set Path=%HmgPath%\util;%HmgPath%\mingw\bin;%HmgPath%\harbour\bin;
Set Resources=%HmgPath%\resources\hmg.o
set GT=-gtgui
set DEBUG=""
set BUILDTYPE=""
set REBUILDALL=""
set RUN=.T.
set MT=
rem
rem Syntax:
rem
rem Build [/i|/r|/d|/cs|/ci/cr] <PrgFile> | <filelist.hbp> [config.hbc]
rem
rem [/i] : incremental build
rem [/r] : incremental build (rebuild all)
rem
rem [/cs] : Console/mixed mode (std build)
rem [/ci] : Console/mixed mode (incremental build)
rem [/cr] : Console/mixed mode (incremental rebuild all)
rem
rem [/d] : Debug mode (gui and console)
rem
rem
rem <filelist.hbm> : A text file with .hbp extension containing a source list
rem <configfile.hbc>: A text file with configuration parameters as additional
rem libs, include paths and lib paths.
rem
rem <configfile.hbc> Syntax:
rem
rem incpaths = incpath1 incpath2 ... incpathn
rem
rem libpaths = libpath1 libpath2 ... libpathn
rem
rem libs = lib1 lib2 ... libn
rem
rem - library names must not include 'lib' prefix nor '.a' extension.
rem
rem - build.bat will create an 'error.log' file in the app folder when build
rem process ends with an error condition.
rem
rem
cls
echo building...
if exist hbmk.hbm del hbmk.hbm
if exist hbmk.log del hbmk.log
if exist windres.log del windres.log
if exist error.log del error.log
if exist _hmg_resconfig.h del _hmg_resconfig.h
rem ---------------------------------------------------------------------------
rem Parameters Processing
rem NO PARAMETERS OR HELP REQUESTED
if "%1"=="" goto syntax
if "%1"=="/?" goto syntax
if "%1"=="-?" goto syntax
if "%1"=="/h" goto syntax
if "%1"=="/H" goto syntax
if "%1"=="-h" goto syntax
if "%1"=="-H" goto syntax
if "%1"=="-help" goto syntax
if "%1"=="-HELP" goto syntax
rem No run after build
if "%1"=="/n" goto norun
if "%1"=="/N" goto norun
:continue0
rem Multi Thread
if "%1"=="/mt" goto multithread
if "%1"=="/MT" goto multithread
:continue1
rem Console Incremental Rebuild
if "%1"=="/cr" goto consoleincrebuild
if "%1"=="/CR" goto consoleincrebuild
if "%1"=="/ci" goto consoleincremental
if "%1"=="/CI" goto consoleincremental
rem GUI Incremental Rebuild
if "%1"=="/r" goto increbuild
if "%1"=="/R" goto increbuild
rem Console Standard Build
if "%1"=="/cs" goto console
if "%1"=="/CS" goto console
rem If debug mode specified, use GTWIN and pass -b parameter
if "%1"=="/d" goto debug
if "%1"=="/D" goto debug
rem If /i parameter rceived set BUILDTYPE to incremental
if "%1"=="/i" goto incremental
if "%1"=="/I" goto incremental
:continue
if exist %~n1.exe del %~n1.exe
if exist %~n1.exe goto error
rem If a resource with the same base name as the first parameter exist compile it
echo #define HMGRPATH %HmgPath%\RESOURCES > _hmg_resconfig.h
echo %HmgPath%\hmg.hbc > hbmk.hbm
if exist %~n1.rc copy /b %HmgPath%\resources\hmg.rc+%~n1.rc+%HmgPath%\resources\filler _temp.rc >NUL
if exist %~n1.rc redir -e windres.log windres -i _temp.rc -o _temp.o
if exist %~n1.rc Set Resources=_temp.o
rem invoke HBMK2
IF NOT "%HMGVER%"=="%APPHMGVER%" IF EXIST .HBMK RMDIR /S /Q .hbmk
rem redir -eo hbmk2 -o%~n1.exe %GT% %DEBUG% %MT% %BUILDTYPE% %REBUILDALL% -incpath=%HmgPath%\include -incpath=%CD% -L%HmgPath%\lib -lhmg -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbvpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage -lhbpgsql -lpq -lhbtip -lhbct -lhbmisc -lhbnetio -lxhb -prgflag=/q -cflag=-O3 %1 %2 %3 %4 %5 %6 %7 %8 %9 %Resources% >hbmk.log
rem redir -eo hbmk2 -o%~n1.exe %GT% %DEBUG% %MT% %BUILDTYPE% %REBUILDALL% -incpath=%HmgPath%\include -incpath=%CD% -L%HmgPath%\lib -lhmg -lhbmysql -lmysql -lcrypt -ledit -leditex -lgraph -lini -lreport -lhbwin -lhbziparc -lhbmzip -lmsvfw32 -lvfw32 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbmemio -lhbsqlit3 -lsqlite3 -lhbfimage -lhbpgsql -lhbtip -lhbct -lhbmisc -lhbnetio -lxhb -prgflag=/q -cflag=-O3 %1 %2 %3 %4 %5 %6 %7 %8 %9 %Resources% >hbmk.log
redir -eo HBMK2 -o%~n1.exe %GT% %DEBUG% %MT% %BUILDTYPE% %REBUILDALL% %1 %2 %3 %4 %5 %6 %7 %8 -i%hmgpath%\include -lmsvfw32 -lvfw32 -lmysql >hbmk.log
goto end
rem Procedure increbuild
:increbuild
set BUILDTYPE=-inc
set REBUILDALL=-rebuild
shift
goto continue
rem Procedure Console
:console
shift
goto continueconsole
rem Procedure Debug
:debug
set GT=-gtwin
set DEBUG=-b
echo Options NoRunAtStartup > Init.cld
shift
goto continue
rem Procedure Incremental
:Incremental
set BUILDTYPE=-inc -head=native
shift
goto continue
rem Procedure IncConsole
:consoleincremental
set BUILDTYPE=-inc
shift
:consoleincrebuild
set BUILDTYPE=-inc
shift
rem Procedure ContinueConsole
:continueconsole
rem echo %HmgPath%\hmgc.hbc > hbmk.hbm
redir -eo HBMK2 -o%~n1.exe %DEBUG% %MT% %BUILDTYPE% %REBUILDALL% %1 %2 %3 %4 %5 %6 %7 %8 -std -i%hmgpath%\include -lmsvfw32 -lvfw32 >hbmk.log
goto end
rem Procedure NoRun
:norun
set RUN=.F.
shift
goto continue0
rem Procedure Multithread
:multithread
set MT=-mt
shift
goto continue1
rem Procedure Error
:error
echo Can't delete previous %~n1.exe version (still running?) > error.log
goto showlog
rem Procedure Syntax
:syntax
cls
echo :: Syntax:
echo ::
echo :: "Build [/i|/r|/d|/cs|/ci/cr] <PrgFile> | <filelist.hbp> [config.hbc]"
echo ::
echo :: [/i] : incremental build
echo :: [/r] : incremental build (rebuild all)
echo :: [/cs] : Console/mixed mode (std build)
echo :: [/ci] : Console/mixed mode (incremental build)
echo :: [/cr] : Console/mixed mode (incremental rebuild all)
echo :: [/d] : Debug mode (gui and console)
echo :: filelist.hbm : A text file with .hbp extension containing a source list
echo :: configfile.hbc: A text file with configuration parameters as additional
echo :: libs, include paths and lib paths.
echo ::
echo :: configfile.hbc Syntax:
echo ::
echo :: incpaths = incpath1 incpath2 ... incpathn
echo :: libpaths = libpath1 libpath2 ... libpathn
echo :: libs = lib1 lib2 ... libn
echo ::
echo :: library names must not include 'lib' prefix nor '.a' extension.
echo :: build.bat will create an 'error.log' file in the app folder when build
echo :: process ends with an error condition.
echo :: <.hbc> files in the current folder are automatically processed.
pause
goto stop
:end
rem Cleanup
rem If build error, create 'error.log' ----------------------------------------
if errorlevel 1 if exist windres.log copy /a windres.log+hbmk.log error.log >nul
if errorlevel 1 if not exist windres.log copy /a hbmk.log error.log >nul
rem If no build error, create 'build.log' ----------------------------------------
if errorlevel 0 if exist windres.log copy /a windres.log+hbmk.log build.log >nul
if errorlevel 0 if not exist windres.log copy /a hbmk.log build.log >nul
rem If no error strip the exe ---------------------------------------------------
if not errorlevel 1 if exist %~n1.exe strip.exe --strip-all %~n1.exe
rem If no error run the exe ---------------------------------------------------
if "%RUN%"==".T." if not errorlevel 1 if exist %~n1.exe %~n1.exe
rem Delete temporary files ----------------------------------------------------
if exist _temp.rc del _temp.rc
if exist _temp.o del _temp.o
rem Create Version Sign -------------------------------------------------------
echo %hmgver%> hmgver.dat
:showlog
if exist error.log type error.log
if exist build.log type build.log
:stop
Mario Mansilla
Hola Rathi :
Perfecto tambien mis aplicaciones ya compilan bien como en HMG.035 .
Ahora bien hay una de ellas en la cual uso la funcion DbZap() con la cual me da error en HMG.036 y no me crea el ejecutable . Cuando la misma aplicacion la compilo con HMG.035 lo hace sin problemas .
¿Que funcion tengo que agregar ?
Saludos .
Mario Mansilla
Hi Rathi:
Perfect also compile my applications and well as in HMG.035.
But there is one in which I use DbZap function () which gives me the error in HMG.036 and I created the executable. When the same application compiled with the HMG.035 do it without problems.
What features do I have to add?
Greetings.
Mario Mansilla
Saludos .
Mario Mansilla
Hi Rathi:
Greetings.
Mario Mansilla
Mario Mansilla
Hola Daniel :
Muchas gracias por contestar . Probe con Alias->(__Dbzap()) y funciona perfecto . Habran hecho cambios en los nombres en Harbour desde la version que venia con HMG.035 con respecto a la nueva HMG.036
Saludos.
Mario Mansilla
Saludos.
Mario Mansilla
Recuerda que la Tabla/Base debe estar abierta en MODO EXCLUSIVO cuando TRABAJES en RED
