Selecting (Choosing) Folders and listing files to a listbox
Does anyone have a small piece of code for selecting a folder using a GetFolder GUI and sending the file listing in that folder to a listbox?
_________________
Sincerely,
Mike
Sincerely,
Mike
Re: Selecting (Choosing) Folders and listing files to a list
OK I think I got it. I kept trying to do it with
aadd or afill but both those methods didn't work. I left here the small bit of code I used.
*Made an edit to the code and added an IF condition because the first item in the listbox was always blank for some reason. Who knows. If anyone knows why it wouldn't work without the manually adding an entry into the first array position give me a shout.
*ChooseInput is a text control which got it's value from the GetFolder function
local aDir := Directory(Main.ChooseInput.Value+"\*.*")
local x
For x:=1 to len(aDir)
if x = 1
Main.afiles.Item(1):=adir[x,1]
Main.afiles.AddItem(adir[x,1])
end if
Next
_________________
Sincerely,
Mike
Sincerely,
Mike
- esgici
Hi Mike
Since you did'nt give a complete (SSW) code, sadly I don't understood your problem(s)
But this prg works well:
I hope that it help you.
PROCEDURE MAIN()
DEFINE WINDOW frmTestDirList;
AT 0, 0;
WIDTH 553 ;
HEIGHT 554 ;
TITLE "Test DIR List" ;
MAIN ;
ON INIT FillDirList()
@ 10, 100 BUTTON btnReLoad CAPTION "Re-Load" ACTION FillDirList()
@ 100, 100 LISTBOX lstbxDirList WIDTH 200 HEIGHT 200
END WINDOW // frmTestDirList
frmTestDirList.Center
frmTestDirList.Activate
RETURN // MAIN()
PROCEDURE FillDirList()
LOCAL cDIRName := GetFolder( "Choose a folder" )
LOCAL aDirList := {}
LOCAL nDirElemNo :=0
IF !EMPTY( cDIRName )
aDirList := Directory( cDIRName )
IF EMPTY( aDirList )
MsgInfo( cDIRName + CRLF + " This folder doesn't contains ordinary file")
frmTestDirList.lstbxDirList.DeleteAllItems()
FOR nDirElemNo := 1 to LEN( aDirList )
frmTestDirList.lstbxDirList.AddItem( aDirList[ nDirElemNo, 1 ] )
ENDIF EMPTY( aDirList )
ENDIF !EMPTY( cDIRName )
RETURN // FillDirList()
*~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Regards
Viva INTERNATIONAL HMG
Excellent, yes thanks, I just figured it out before you posted it.
I am curious though how come you added this line
Why does the listbox create an empty item on initialization?
That's not important but I figured I would ask.
Thanks again!
frmTestDirList.lstbxDirList.DeleteAllItems()That's not important but I figured I would ask.
Thanks again!
_________________
Sincerely,
Mike
Sincerely,
Mike
If you don't delete the items in the listbox, every time when you click the button, the items are added last to the listbox.
- esgici
You are right, it's unnecessary on initialization, required when call by button.nassausky wrote:... I figured I would ask.
But it's also unnecessary testing calling sequence ( called by ON INIT or BUTTON ?) and seperating process ( emty or not) within sub-procedure.
It isn't ?
