About HMG docs
Carlos Britos
Re: About HMG docs
Hi I'm asking in Firefox forum.
BTW I'll commit some changes in htm headers, please if your are so kind to rebuild doc and test it, while I'm waiting for some explanation from Firefox.
Carlos Britos
Re: About HMG docs
Hi
Below is the version 20110521 of hmgdoc.exe.
Fixed the problem with FireFox 4.01.
Current version was tested on browsers:
IE 7.x and higher
FireFox 3.5.x / 4.01
Opera 10.x / 11.x
QT Browser (sample)
If someone else can test it in another browser, please let me know.
Sorry for the inconvenient and delay to fixit.
IE 7.x and higher
Opera 10.x / 11.x
QT Browser (sample)
- cap1.png (56.15 KiB) Viewed 6322 times
Re: About HMG docs
Thanks a lot Carlos Britos! Nice fix.
Re: About HMG docs
gvaronas wrote:Hola Carlos, despues de generar la ayuda, en firefox no se visualiza bien, pero con el IE funciona bien.
Salu2,
GVS
Hola Carlos, Muchas gracias por mantener actualizada la documentación.
Resulta que ahora se me actualizó el FireFox a 5.0 y se ha vuelto a presentar el mismo problema.
Nuevamente, muchas gracias por tu trabajo.
Hi Carlos, Thanks for keeping the documentation.
It turns out that now I upgraded to 5.0 and FireFox has resubmitted the same problem.
Again, thank you very much for your work.
BestRegards
GVS
- moz-screenshot-2.png (114.51 KiB) Viewed 6280 times
Carlos Britos
Re: About HMG docs
BestRegards
GVS
Carlos Britos
Re: About HMG docs
I've installed Firefox 5.0b7 and hmgdoc works as expected, maybe you are using the old version please check it from command line . hmgdoc -versionCarlos Britos wrote:I'll check it as soon as possible. Thanks for report.gvaronas wrote: Hi Carlos, Thanks for keeping the documentation.
BestRegards
GVS
Should be 20110521
- cap2.png (63.29 KiB) Viewed 6268 times
Carlos Britos
Re: About HMG docs
Hi rathinagiri
For the next release of hmg4 binary package. Can you do this ?:
- Del subdir Data: C:\hmg.4\svn\doc\data
- Add hmgdoc.exe to: C:\hmg.4\harbour\bin
- Add images docs to those that are already in: C:\hmg.4\svn\doc\res
Get it from: viewtopic.php?p=16370#p16370
In this way the user can get fresh htm help docs.
and ( but not related to hmg docs )
- Add Images QT dll files. C:\hmg.4\qt\plugins\imageformats
- Del subdir hmg: C:\hmg.4\svn\hmg
IMHO two folders with different sources and samples could be a problem.
Re: About HMG docs
Ok. Noted.
Carlos Britos
Re: About HMG docs
HI
Below is the version 20110627 of hmgdoc.exe.
Fixed to build a better FAQ section and other minor stuff.
