Hi All
Take a look at this function :-
Function BrMove(met)
do case
case met == 1
dbGotop()
_GridHome ( "Browse_1",thiswindow.name )
case met == 2
_GridPgUp ( "Browse_1",thiswindow.name )
case met == 3
dbSkip(-1)
_GridPrior( "Browse_1",thiswindow.name )
case met == 4
dbSkip(1)
_GridNext ( "Browse_1",thiswindow.name )
case met == 5
_GridPgDn ( "Browse_1",thiswindow.name )
case met == 6
dbGoBottom()
_GridEnd ( "Browse_1",thiswindow.name )
endcase
Problems
1. For case met == 6, it will not go to the last record but instead it will stop at the last record within the visible Browse
Assuming Table has a 100 records and Browse shows say 30 records, I expect it to go to record 100. Instead it stops at Record 20
2. For case met == 5, it will not go to the next page but instead it will stop at the last record within the visible Browse
Assuming Table has a 100 records and Browse shows say 30 records, I expect the Browse to show records 31 to 60. Instead
3. For case met == 4, if cursor is at say Record 20, this will stay at Record 20
Q. What must I do to get the Browse to behave as expected ?
TIA
CCH
http://cch4clipper.blogspot.com
Navigating a BROWSE
Re: Navigating a BROWSE
About met ==6 try this sequence, if it satisfying for you:CCH4CLIPPER wrote:Hi All
case met == 6
dbGoBottom()
endcase
Problems
dbGoBottom()
SetProperty(thisWindow.name,"Browse_1","Value", recno() )
It will move pointe of Browse to last record
regards, Marek
Hi CCH,
Have you given the command at first :
SET BROWSESYNC ON
Regards.
SET BROWSESYNC ON
Regards.
Hi Marek
Hip ! Hip ! Hooray !
SetProperty(thisWindow.name,"Browse_1","Value", recno() ) works perfectly !
BTW, I had somehow expected you to give the right advice
TQVM
CCH
TQVM
CCH
I knew that works good, because I use it in my program...
