One to Many Form
Re: One to Many Form
I use Crimson Editor as suggested by Esgici.
sudip
Post by sudip »
Hello Rathinagiri,
Thanks. I downloaded it and installed. And shall give you feedback after trying with it.
Regards.
sudip
Post by sudip »
I am learning HMG slow but steadily. Your advice and encouragement help me a lot to do this :)
I just added more features in 1-2-many form demo project.
1) Added Browse in the right side of the window for navigation.
2) When anything changed, navigation buttons and browse became disabled.
[img]
[/img]
You can download the source code from here
demo.zip
(3.01 KiB) Downloaded 1287 times
How to compile:-
1. Please extract the downloaded file, demo.zip, into a folder.
2. Go to command prompt and change directory to that folder.
3. Run C:\HMG\BATCH\COMPILE demo
This will create an exe file. Please run the exe file (it will automatically create required tables)
Please advise me how to improve the project (yes, I am working daily as per your advice, and learning HMG) :)
Thank you very much for your support in learning HMG. :)
Hi Rathi, Esgici I used Crimson editor to write this version. It's a very good editor. For final formatting I used xMate's editor.
With best regards.
Hi Sudip
sudip wrote: ...
If you use Crimson Editor newly, probably you need look at one of our early posts:
http://hmgforum.com/viewtopic.php?f=9&t ... imson#p576
sudip
Post by sudip »
Hello Esgici,
I configured it as per your advice.
Thanks a lot! :)
It's an excellent editor.
With best regards.
