HMG 3.0.36 (Test)
Re: HMG 3.0.36 (Test)
Yes I did.
As you can see from my picture above, on my PC the two buttons in the /SAMPLES/MAIN.DEMO are empty.
And there the buttons aren´t defined in the rc-file but in the source:
Line #188: DEFINE BUTTON ImageButton_1 ....PICTURE 'button.bmp' .....
Even this didn´t work here. I only extracted you 3.36 Version and the small Update.
Ricci,
Can you please attach the main.demo folder contents in a zip file here. (Either including or excluding the exe file.)
- MAIN.DEMO.ZIP
- (801.62 KiB) Downloaded 407 times
- luisfrancisco62
felicidades por la version, quisiera saber si esta version seguira evolucionando o necesaria mente nos toca migrar a hmg4?..
gracias muchas gracias
- srvet_claudio
Hi Rathi,
very thank!!!
Claudio.
very thank!!!
Claudio.
- esgici
Hi All
I can't achieve using this version for console mode
Any idea
Regards / Saludos
Any idea
Regards / Saludos
Viva INTERNATIONAL HMG
- Roberto Lopez
- HMG Founder
Thanks!rathinagiri wrote:You can download the 3.0.36 (Test) bundle from the following link.
hmg.3.0.36.test.zip (70 MB)
Hi Roberto,
I think it is the old link.
You can get the recent one from here.
http://hmgforum.com/viewtopic.php?f=2&t=1975
Now we have problem in build.bat that I will list one by one.
- Roberto Lopez
- HMG Founder
Ok.rathinagiri wrote:Hi Roberto,
I think it is the old link.You can get the recent one from here.
I've done a very very quick review on '36' build.
Why is the reason to have two build batch files?
Maybe we should left the new one only and simply drop the old one.
We could simply fully rely on hbmk2 using the batch file only to simplify the things a little, just like the new batch does.
If we follow this way, we should change the version number to a ie: 3.1.0 to make clear that some important change was made.
This do noes affect backwards copatibility since it referes to a build procedure and not the language itself.
- Roberto Lopez
- HMG Founder
And... I've found a problem in multiselect grid setvalue (it appears at least from 3.0.35).rathinagiri wrote:Now we have problem in build.bat that I will list one by one.
Had someone discovered the problem and tried a solution for it ?
TIA.
