About RELEASE on a form
jparada
Post by jparada »
Translated by Google,
I have something typical, one form, the definition MAIN, it calls to other prg's, in another prg, I have something like this:
// In this way, mark the error: btnCancelar Of frmClientes No defined,
IF PCOUNT( ) # 0
* IF MsgYesNo('Desea Salir?','Mensaje')
frmClientes.RELEASE
* ENDIF
IF frmClientes.BtnCancelar . . .
// In this way made no mistake and mark the expected behavior, I go back to main menu,
IF PCOUNT( ) # 0
@500, 50 BUTTON btnCancelar OF frmClientes CAPTION 'Salir' ACTION frmClientes.RELEASE
* ENDIF
I may be doing wrong or why is this behavior, even in the form MODAL (where error mark), I can close the form without any problem with ALT + F4.
Any idea what might be happening and how to fix it?.
Thanks
Greetings
Javier
Spanish,
Tengo algo típico, un form, con la definición MAIN, este llama a otros prg's, en algún otro prg, tengo algo como esto:
// De esta manera marca el error: btnCancelar Of frmClientes No defined,
IF PCOUNT( ) # 0
frmClientes.RELEASE
* ENDIF
// De esta manera no marca error y realiza el comportamiento esperado, me regresa al menú principal,
IF PCOUNT( ) # 0
* ENDIF
Qué puedo estar haciendo mal, o porqué es este comportamiento, incluso en el form MODAL, (donde marca error), puedo cerrar el form sin ningún problema con ALT+F4.
Alguna idea de lo que pudiera estar pasando y como solucionarlo?.
Gracias
Javier
Re: About RELEASE on a form
Hi Javier
HMG Help says :
DECLARE WINDOW <WindowName>
A window must be declared using this command, if you need to refer to it prior
its definition in code, or when you refer to it in a different .prg file from
the one it was defined using semi-oop syntax.
Does your problem may be related with this ?
jparada
Post by jparada »
Hi Esgici, Thanks for reply.
Apparently is not related to the issue of DECLARE WINDOW, since I am not referring to another window than the current one, my current window is called frmClientes defined as follows: DEFINE WINDOW frmClientes in the same Prg showing the problem with the code shown above.
Another thing I want to say is that frmClientes.RELEASE to completely abandon the program and generates ErrorLog.Htm, which shows that the error is pointed out that: Not defined btnCancel Of frmClientes which is part of the code continues.
I have also tried RELEASE WINDOW frmClientes result is the same error.
Thanks
Greetings
Javier
Hola Javier
I can't understand the problem by this very few lines.
Could you post your program after "concentrated to error", that is extracting all lines not related with error ?
May be more convenient if you attach it in compressed form.
luisvasquezcl
Post by luisvasquezcl »
Hola Javier
el problema es que la funcion que libera la ventana no la ve. Para solucionar este problema puedes hacer lo siguiente
PROCEDURE Salir
DECLARE WINDOW miventana
IF PCOUNT() # 0
IF MSGYESNO( ...... )
miventana.RELEASE
creo que esto deberia solucionar tu problema
jparada
Post by jparada »
Thanks for answering Esgici and Luis, for the moment I've solved by reversing the order of conditions, as follows:
IF PCOUNT( ) # 0
frmClientes.RELEASE
Currently is working as expected, so I do not understand is that the error is if I invested, I understand that erases the memory frmClientes form, and so if the flow of the program referred to as frmClientes and no mark error there, but I thought that by placing the release had to leave immediately and do not follow the program flow in this case the IF, or I'm wrong.
Thanks
Greetings
Javier
Spanish,
Gracias por contestar Esgici y Luis, de momento lo he resuelto invirtiendo el orden de las condiciones, así:
IF PCOUNT( ) # 0
frmClientes.RELEASE
De momento éstá funcionando como se espera, lo que no entiendo es porque el error se presenta si lo pongo invertido, entiendo que borra de memoria el form frmClientes, y por eso si continúa el flujo del programa como se hace referencia a frmClientes y ya no existe marca error, ahora bien yo pense que al poner el RELEASE debia salir inmediatamente y no seguir el flujo de programa en este caso del IF, o estoy equivocado.
Gracias
Javier
luisvasquezcl
Hola Javier,
El flujo del programa continúa.
Tienes que separar lo que corresponde al manejo de ventanas y el flujo del programa; al poner release eliminas la ventana de la memoria pero el flujo continúa su proceso hasta el return.
Luis Vasquez
jparada
Post by jparada »
Hi Luis, Thanks for the clarification.
Greetings
Javier
Spanish,
Hola Luis, Gracias por la aclaración.
Javier
