Using #define funtion
raymanw
Post by raymanw »
Hi all,
I defined a function(?) ItemAmt in calculate.ch file. Include the file in the module I want to use the function. ie. #include "calculate.ch"
I can compile & generate an exe successfully. But when I open the form it gives me "Error BASE/1001 Undefined function: ITEMAMT".
What am I missing?
Thanks.
Re: Using #define funtion
Can you show the exact definition part in .ch file?
When you define something with #define you must remeber that all is case sensitive.
Am I wrong? :lol:
raymanw
Post by raymanw »
Hi Rathinagiri,
This is in my calculate.ch file:
#define ItemAmt(weight, price, length, workmanshp, amount) Iif(amount = 0, Iif(weight != 0, weight * price, 0) + Iif(length = 0, workmanshp, workmanshp * length), amount)
I call it as an item in the COLUMNFIELDS of a grid.
'ItemAmt(Iif(StkItem->orig_qty=0, StkItem->weight, StkTrans->weight), GetPurcPrice(StkTrans->g_type, StkTrans->i_type, StkTrans->item), Iif(StkItem->orig_qty=0, StkItem->length, 0), Iif(StkItem->orig_qty=0, StkItem->workmanshp, StkTrans->workmanshp), Iif(StkItem->orig_qty=0, StkItem->amount, 0))'
Hi Mol,
I do matching the case when using.
Thanks.
Why don't you simply declare this function without #define ???
I can't understand reasons of this declaration.
Marek
raymanw
Post by raymanw »
Hi Mol,
Yes. I came to that conclusion as well. This is a piece of old Clipper code. I would still be interested to see how it should be under Harbour. But I think I should post this in the Harbour forum/group rather than under HMG's.
Thanks.
