There are still some bugs, don't do a new release on today svn !rathinagiri wrote:Thanks a LOT for your update. It is great.
First I want to unite Browse, Grid and VirtualGrid.
Ok. I won't.
I want to process the 'enter' or 'return' key to act as a tab key for "set navigation extended".
For this, I took "TextBox" as sample and added a 'connect' like this around in /source/textbox.prg at line number 568.
I have added in control.prg as under.
I could not get it to work. It gives runtime error at sendEvent().
::oQTObject:connect( QEvent_KeyPress , {|e| ::DoControlKeyBoardEvents( e )} )
* control.prg
METHOD DoControlKeyBoardEvents( e ) Class CONTROL
LOCAL oKeyEvent := QKeyEventFromPointer( e )
LOCAL nKey := oKeyEvent:key()
LOCAL nModifiers := oKeyEvent:modifiers()
LOCAL oNewKeyEvent
IF (nKey == Qt_Key_Return .and. nModifiers == Qt_NoModifier ) .or.( nKey == Qt_Key_Enter .and. nModifiers == Qt_KeypadModifier )
oNewKeyEvent := QKeyEvent( QEvent_KeyPress, Qt_Key_Tab, Qt_NoModifier, 'Tab', 0, 1 )
::s_qApp:sendEvent( ::oQTObject, oNewKeyEvent )
oNewKeyEvent := QKeyEvent( QEvent_KeyRelease, Qt_Key_Tab, Qt_NoModifier, 'Tab', 0, 1 )
RETURN .F.
RETURN .F.
There were problems with sendEvents code and they were solved last week, after rev 16420. You need to wait.
Thanks for the info.
Francesco,
Had you updated HMG 4.0 source in line with latest Nightly build?
Or, Shall I start doing?
I'm 24/24 on hbQt now. There is a problem with the new code and we are investigating. So please don't update the hmg-4 sources in svn yet otherwise no-one will be able to compilerathinagiri wrote:Francesco,
Ok Francesco,
I will wait for your signal.
Carlos Britos
Himrduck wrote:So please don't update the hmg-4 sources in svn yet otherwise no-one will be able to compile
I've made Dial class, here is the code to upload if it is accepted.
- dial.zip
- (2.81 KiB) Downloaded 183 times
2011-04-01 20:00 UTC+0530 Rathinagiri (<srgiri@dataone.in>)
* source/browse.prg
* source/datepicker.prg
* source/monthcalendar.prg
* source/grid.prg
* source/listbox.prg
* source/printer.prg
* source/windows.prg
* source/virtualgrid.prg
* Changes according to the latest version of HBQT. Thanks for the contribution by Francesco.East or West HMG is the Best.
