Hi all !
In HMG4 the font property of all objects are initialized when the object is being created.
In this way, in some cases, it´s not possible to set font properties of an object before it´s creation.
And in some classes the font property is not explicitly settled. In this case, since the controls works as expected, I assumed that a default font is previously settled by the QT framework.
I suggest to assign the font property in a lower level, in the CONTROL class, since almost all objects inherits form CONTROL.
And font management methods are already in CONTROL.
And since I will need to change almost all object classes that descends from CONTROL I would hear from you if is this Ok or if I am missing something.
Font in control class
[[]] Mauricio Ventura Faria
Re: Font in control class
IMHO, as far as the changes are HMG 3 compatible backward, we can do anything to improve.
This may be a problem since I have never used HMG 3...
No problem. Please go ahead. Let us see what happens.
OK. I am confident that no code will be break.
But before I commit the changes, I will test all samples in the SVN.
Hi, forgive me for intruding, but after reading this post I take a look to control.prg and window.prg.
Both contain the definition of the oFont var: why? This is the only case?
The point made is very important and I would add: if there are other cases, perhaps it would be enclosed within control.prg all common properties and methods.
Best regards
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
Hi.
Having some trouble in this task...
OOP is a bit difficult because there are no NEW() method in almost all classes inherited from CONTROL.
In this way, whenever a control is created the NEW() form the control class is called ( inheritance ) but the control is nothing usable, it is only controlling stuff.
It´s not possible to set any specific property before the control is created by the CREATE() method.
Classes inherited from WINDOW does not suffer this lack of NEW() methods.
I have an idea of what to do but since I do not know the innards of the lib and need some help from the seniors !
For me the CREATE() method should be changed to a NEW() method or splitted in a CREATE() and NEW() classes. My guess is that the split approache is the way to go...
Hello Concentra,
I'm not the best qualified to criticize your idea; I'm also experimenting with the new library, the code and the use of classes
I hope that my explanation is not misplaced
The "CREATE" method is used to create the QT object, while the HMG object has already been created by "NEW" method.
I can describe the flow in this way:
- create objects to the level of HMG ("NEW" method);
- create objects to the level of QT (from form see "ACTIVATE" method);
- Activating the form and bla, bla, bla...
IMHO, partly agree with you is that - perhaps - it is better to distinguish "NEW" method for each control
But it's my personal opinion.
Cheers
![Wink ;)](./images/smilies/icon_e_wink.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
![Laughing :lol:](./images/smilies/icon_lol.gif)
![Idea :idea:](./images/smilies/icon_idea.gif)
Cheers
Luigi from Italy
www.L3W.it
www.L3W.it
