HMG4 event idea
l3whmg
HMG4 event idea
Post by l3whmg »
Hello everyone, I would like to have your opinion on whether to add two events to the form.
The names could be: "OnBeforeShow" and "OnAfterShow".
These two events would be triggered immediately before and after the statement "oQTObject: Show ()" in window.prg.
The reasons for this request is: often, it is useful to fill in the fields after a processing or perform a procedure, etc.
Since the form is not yet completely loaded I get errors
Another example that comes to me is this: in the OnInit function of the main form, I have to open another form. Based on the result of this operation I have to figure out whether to continue or not. With Hmg4 I have problems, but using the assumed event OnAfterShow everything works fine.
What do you think about this idea?
Luigi from Italy
www.L3W.it
Re: HMG4 event idea
Hi Luigi,
Kindly create the code along with some samples to demonstrate the same. Definitely your suggestion will be useful to all.
Thanks.
Re: HMG4 event idea
l3whmg wrote: ...
Hi Luigi
Good idea :idea:
Please continue :)
l3whmg
Re: HMG4 event idea
Post by l3whmg »
Hi guys,
Today it's not a good day..... I've written code but without good news :oops:
In fact, HMG4 have different core from HMG3: when you change a value inside OnInit event and other field depend by OnChange clause of this, with HMG3 you can receive error. with HMG4 no :D
I was hoping to find a way to see or do something immediately after the appearance of the form on the video, but without result. In according with documentation provided by QT, I created an event OnAfterShow, but I get the same result with the OnInit event. bAfterEvent first runs and then you see the form. In fact, putting a trivial MsgStop, I see the message first and then I see the form.
Anyway, this is a piece of code for windows.prg
/*----------------------------------------------------------------------*/    //L3W
METHOD OnAfterShow( bValue ) CLASS WINDOW                                     //L3W
        //L3W
   IF ::lCreated                                                              //L3W
      IF PCOUNT() == 0                                                        //L3W
         RETURN ::bOnAfterShow                                                //L3W
      ELSEIF PCOUNT() == 1                                                    //L3W
         ::bOnAfterShow := bValue                                             //L3W
         IF .NOT. ::oQTObject:connect( QEvent_Show , {||EVAL( bValue ) } )    //L3W
            ::oQTObject:disconnect( QEvent_Show )                             //L3W
               // Error                                                       //L3W
            ENDIF                                                             //L3W
         ENDIF        //L3W
      ENDIF        //L3W
   ELSE        //L3W
      ELSEIF pcount() == 1                                                    //L3W
      ENDIF        //L3W
   ENDIF        //L3W
        //L3W
   RETURN NIL        //L3W
And this was translation command to use with DEFINE WINDOW
#xcommand ONAFTERSHOW         <bvalue>  =>   :OnAfterShow         := <{bvalue}>
If someone have a better idea....
Best regards
Luigi from Italy
www.L3W.it
