No HMG4 Font object
No HMG4 Font object
I am new to HMG and am converting a FiveWin printing tool to HMG4 and I was unable to find references to FONT objects in HMG4...
HMG4 don´t have FONT objects ?
In FiveWin I can create independent FONT objects and set them to other objects like PRINT, WINDOW, etc.
In HMG4 this is not possible ? Or do I have to manipulate QT font objects directly ?
Another thing I considered strange is that if an incorrect or invalid printer is selected, the printing subsystem will only manage this AFTER generating the full report. Im my opinion this would be checked earlier, in the printer selection functions. I think I am able to make this change by myself but the development managers have to agree and I also don´t have access to make changes in the SVN.
Where can I find QT documentations ?
Maurício Faria
Maurício Faria
[[]] Mauricio Ventura Faria
Re: No HMG4 Font object
Hola Mauricio
Puedes mirar hmg.4.html dentro de la carpeta ..\doc en tu instalacion HMG.4
en HMG4 Release 28-10-10 http://hmgforum.com/viewtopic.php?f=2&t=1754
tienes varios Ejemplos sobre PRINT y manejo de FONT
instala primero esta version y actualiza despues con la nueva version liberada 01-02-11
baja Tortoise SVN para mantener actualizado la carpeta ..\..\Samples
http://tortoisesvn.tigris.org/
Lenguaje Portugues para Tortoise
http://sourceforge.net/projects/tortois ... i/download
despues lee esto
despues lee esto
SaludosHMG.4 2011.02.01 README
- The samples are in svn/samples folder.
- To build a sample type
build <sample>
- To distribute your executable you must provide all dll files located at qt\bin
folder. If your app uses .jpg, .gif, .ico, or .tif files you must provide the
plugin dlls located at qt\plugins\imageformats with the qt.conf file pointing
to dll files location in the target system.
- The sources are in svn/source folder.
- If you want to get updated sources, you can download at:
http://hmg.svn.sourceforge.net/viewvc/hmg/?view=tar
and unpack the content of hmg folder at c:\hmg.4\svn (you can unpack it with winrar).
- If you are a project contributor:
1. Download Tortoise SVN client (http://sourceforge.net/projects/tortoisesvn/).
2. Install according the setup wizard directions.
3. Open Windows explorer.
4. Right click in the C:\HMG.4\SVN folder.
5. Select 'SVN Checkout' (project url is: https://hmg.svn.sourceforge.net/svnroot/hmg).
6. If you change the code of your local copy and want to upload, Right click in
the C:\HMG.4\SVN and select SVN Commit...
7. If you want download the changes from the server, Right click in
the C:\HMG.4\SVN and select SVN Update.
- To become a contributor you need a SourceForge.net account and must be to be
authorized by the HMG team at http://www.hmgforum.com.
danielmaximiliano wrote:Hola Mauricio
Daniel, I did it, but was unable to find any sample about PRINT nor FONT management in hmg.4.html ...
I only see a HMG 4.0 Status Report on 2010-09-24.
Will do a SVN checkout to see what I get in the current trunk...
[[]] Maurício Faria
mauricio, guarda este ejemplo en tu carpeta Samples como
..\Samples\Print
Pd: Samples completo
..\Samples\Print
- samples.rar
- Ejemplos completo
- (1.11 MiB) Downloaded 433 times
- print.rar
- (13.45 KiB) Downloaded 352 times
danielmaximiliano wrote:mauricio, guarda este ejemplo en tu carpeta Samples como
..\Samples\Print
Daniel thahks, but I already had this samples.
Maybe I wasn´t clear in what I am looking for.
Forget about printing, I am looking for FONT management functions.
Like defining a FONT object and manipulating their properties like font name, size, bold, italic, etc.
[[]] Maurício Faria
Maurício Faria,
Thanks a lot for your interest.
As of now, our main concern is to port HMG 3 applications to HMG 4. In HMG 3, we have separate definition of fonts for each control. (Since HMG 3 is not an OOP model).
Definitely a separate font object will be required and we have to create the same in the future.
Ok, I see.
May I try to write this ?
Who authorizes write access to SF ?
[[]] Maurício Faria
[[]] Maurício Faria
If you want, yes you can.
Kindly give your SF username.
Hi, Rathinagiri.
My SF id is concentra.
But, while studying HMG4 in order to do the job, I realised that it´s easier to work with the QFont object directly since all HMG4 controls uses fonts in this way ( directly ) !
Maurício Faria
Maurício Faria
While testing some code I found some weird behaviors...
One is that in a BUTTON, when changing the button caption I need to change 2 properties -> :caption and :cCaption !
If I change only one ( any one ) the button caption do not change !
Is this the expected behavior or am I doing something wrong ?
PLease test the folowing code with the latest HMG4 (02/2011) :
Local oWindow , oButton1
With Object oWindow := Window():New()
:Width := 200
:Height := 80
:Type := WND_MAIN
With Object oButton1 := Button():New()
:Row := 20
:Col := 20
:Width := 160
:Caption := 'Click to Change Caption !'
:OnClick := { || ChangeCaption(oButton1) }
End With
End With
oWindow:Activate()
FUNCTION ChangeCaption(oButton1)
Static lOnOff
IF lOnOff == NIL
lOnOff := .T.
IF lOnOff
oButton1:cCaption := 'Click to change back...'
oButton1:Caption := 'Click to change back...'
oButton1:cCaption := 'Click to Change Caption !'
oButton1:Caption := 'Click to Change Caption !'
lOnOff := ! lOnOff
:Width := 200
:Height := 80
:Type := WND_MAIN
:Row := 20
:Col := 20
:Width := 160
End With
End With
oWindow:Activate()
Static lOnOff
IF lOnOff == NIL
lOnOff := .T.
IF lOnOff
lOnOff := ! lOnOff
