XML for spreadsheets
Re: XML for spreadsheets
I don't think so. :) (At least for exporting)
sudip
Post by sudip »
Hi Rathi,
I said this because I found following line in the HMG\Harbour\ChangeLog file
  * contrib/xhb/hbxml.c
There may be some functions which can handle xml nodes easily. But, I may be wrong, as I have very little (almost zero) knowledge about xml files. ;)
Thanks in advance :)
Yes. That is there. IMHO, that would be very much useful for retrieval from xml file than exporting.
sudip
Post by sudip »
Yes, Rathi. You are correct :)
Actually I am searching for a better method for both read from xml file and export to xml file.
I saw some examples in other Harbour/xHarbour libraries, but yesterday I was not able to transfer them to HMG ;)
Kana
Post by Kana »
sudip wrote:Hello All,
I want to export my data in XML format, so that it can be opened with any modern spreadsheet. Is there any easy way to do this? Or I shall write all the XML codes ...
Is there any utility which can export DBF to XML? Or Grid to XML :)
(After 15 minutes: IMHO, it is not very complex to write code for DBF2XML, I shall do it :) )
One of the ODBC or ADO version:
Function Table2XML(oRecordSet, cTable, cFile)
  LOCAL nFields
  LOCAL nHandle
  LOCAL cBuffer
  LOCAL i:=1
  #define CRLF Chr(13)+Chr(10)
  if cFile=NIL
     cFile:="tmp.xml"
  end
  nHandle:=fCreate( cFile, 0 )
  nFields := oRecordSet:Count()-1
  DO WHILE .NOT. oRecordSet:Eof()
    cBuffer:=Space(2)+"<"+cTable+">"+CRLF
    fWrite(nHandle,cBuffer)
    FOR nField:=0 TO nFields
      cBuffer:=Space(4)+"<"+oRecordSet:Fields(nField):Name+">"//Beginning Record Tag
       DO CASE
         CASE Valtype(oRecordSet:Fields(nField):Value) == "D"
           cValue := Dtos(oRecordSet:Fields(nField):Value)
         CASE Valtype(oRecordSet:Fields(nField):Value) == "N"
           cValue := Str(oRecordSet:Fields(nField):Value)
         CASE Valtype(oRecordSet:Fields(nField):Value) == "L"
           cValue := If( oRecordSet:Fields(nField):Value, "True", "False" )
         OTHERWISE
           cValue := oRecordSet:Fields(nField):Value
       ENDCASE
       cValue:=strTran(cValue,"&","&")
       cValue:=strTran(cValue,"<","<")
       cValue:=strTran(cValue,">",">")
       cValue:=strTran(cValue,"'","&apos;")
       cValue:=strTran(cValue,["],["])
       cBuffer:=cBuffer             + ;
                Alltrim( cValue )   + ;
                oRecordSet:Fields(nField):Name + ;
                CRLF
    NEXT nField//Ending Record Tag
    fWrite(nHandle,Space(2)+"</"+cTable+">"+CRLF)
    oRecordSet:MoveNext()
    ? ++i
  ENDDO
  oRecordSet:Close()
  fClose(nHandle)
Return nil
swapan
Post by swapan »
Very good initiative Sudip!
I've seen the TALLY ACCOUNTING PACKAGE (most widely used FA package in India) having the facility of importing & exporting data in XML format. If they have choosen this medium then this can be a very "happening" medium of exchange of data between two applications.
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
nguyenchiduc
Post by nguyenchiduc »
sudip wrote:Yes, Rathi. You are correct :)
Not only for XML
With any simple file structure that we know, we can use low level functions to read and write.
Sometimes for a dbf file sizes larger in PC or SQL Server, we only need to export a few fields only.
And otherwise from the XML to dbf
Depending on the purpose we will write your own functions to import/export
