scanner fingerprint web cam image capture willing to pay
mexicanto
hello to everybody
i am reposting this topic, with a new subject, in case someone is interesting in this
i need this
a source code for scanning images, and save the images in a data base, not in a diferent file
(any brand of scanner)
a source code for capture images from a web cam, and stored in a database, not a external file
(preferibly logitech web cam, but if it works from any brand, even better)
a source code for fingerprint reader (for a employee recognition), capture the fingerprint, store it in a data base, and later, compare that fingerprint with the one that the user input at a login screen
(the fingerprint is a digital persona u.are.u 4500)
all in source code, full of explanations, because i am coming back from clipper summer 87, and i am still learning about the gui
the code have to be free of royalties, because i want to use that code in different programs, and different machines
if you are interested in this project, just let me know the price, and the time for the development
thank you very much
daniel gaitan
mexicanto
i need this
thank you very much
daniel gaitan
mexicanto
Re: scanner fingerprint web cam image capture willing to pay
Hola Daniel:
tengo un fingerprint Sony FIU-600 pero nada de drivers para Windows, veo que Ubuntu la distribucion de linux lo soporta con la libreria Libprint http://www.reactivated.net/fprint/wiki/Libfprint
si encuentro algo te aviso para probar sobre HMG
Saludos DaNiElMaXiMiLiAnO
tambien hay algo para Scanner de barras
http://www.tuxbrain.com/content/c%C3%B3 ... aplicacion
mexicanto
saludos daniel (que buen nombre te pusieron
te cuento que yo de linux no se nadita de nada
pero sigue mi oferta, si alguien desea desarrollar el codigo
para lo que necesito, me gustaria compensarle monetariamente
el tiempo que invirtio en el proyecto
las computadoras que uso solo tienen el windows xp, y solo pueden
utilizar el xp, por cuestiones de que utilizan otros programas tambien
gracias
gracias
mexicanto
saludos nuevamente, espero que algun valiente se atreva a cumplir con este reto
de verdad lo necesito, y como son sitemas que me van a pagar, no tengo problema con pagarle tambien a la persona que ayude con ello, y ademas, podemos hacer publicos los fuentes, para el beneficio de toda la comunidad de hmg
se que es algo dificil, tal vez hasta el mismo sr roberto se interese en desarrollarlo, como comente antes, me gustaria mucho pagar, y pagar bien este arduo trabajo
muchas gracias
muchas gracias
Hola,
Aqui tienes un link con algo referente a tus necesidades, echale una mirada a ver si te ayuda en algo.
http://forums.fivetechsupport.com/viewt ... =3&t=11462
Javier
Javier
Hola, le cuento que yo he logrado capturar imagenes desde la webcam ha un archivo JPG
Desde hace mucho tiempo he investigado para usar con hmg, el lector de huella digital, he visto ejemplos FUNCIONANDO en c, visual foxpro,java ETC, pero no he logrado usarlos con hmg.
el hilo va en que se usan unos dll que son los que se comunican con el scaner...
NO HE LOGRADO que a travez de hmg, pasarle los parametros para que responda...
LO HE INTENTADO POR MUCHOS MEDIOS pero nada, por eso deje el proyecto de un lado.
si puedo colaborar en algo... por favor me informa... para retomar este tema que me apasiona
ya en este foro puse varios post,,, usando buscar HUELLA podra encontrarlos
cordial saludo
cordial saludo
mexicanto
saludos jucar, me podrias informar como es que lograste capturar las imagenes de web cam a jpg con el home ??
muchas gracias por tu ayuda
estoy con el SDK del digitalpersona
es un activex
puedes bajarlo gratis en www.digitalpersona.com
gracias por toda la ayuda que me puedan brindar
es un activex
Adjunto fuentes para tomar foto con web cam
Para que funciones la camara debe set compatible TZWAIN
cualquier cosa..
El controll activex ya lo habia bajado, lo que no se es como desde hmg COMINICARSE CON ESE CONTROL
pues debe registrarse y mas...
en este programa se cominica con la DLL que es lo que pretendo hacer con el lector de huella pero no he podido
GRACIAS
cualquier cosa..
GRACIAS
- WEBCAM.ZIP
- (801.38 KiB) Downloaded 416 times
mexicanto
jucar, que marca y modelo de fingerprint tienes ?
vi un ejemplo de lectoras de huella para fivewin, en un foro de brasil
crees que te pueda servir verlo ?
busco la direccion y te la pego aqui
gracias
gracias
