Yes. This would be really make HMG working in a bug free environment. Thanks man. We can change all the signals and events like this.mrduck wrote:Last message for today, I promise
see this code:I propose some changes (code not tested, it's just a proposal)Code: Select all
METHOD OnClick( bValue ) CLASS CONTROL IF ::lCreated IF Pcount() == 0 RETURN ::bOnClick ELSEIF Pcount() == 1 ::bOnClick := bValue *::oQTObject:DisConnect( "clicked()" ) ::oQTObject:Connect( "clicked()" , ::bOnClick ) ENDIF ELSE IF pcount() == 0 RETURN ::bOnClick ELSEIF pcount() == 1 ::bOnClick := bValue ENDIF ENDIF RETURN NIL
A bit of code refactoring, a bit of parameter checking, a bit of error reporting.... just an idea....Code: Select all
METHOD OnClick( bValue ) CLASS CONTROL // one code for both ::lCreated values IF Pcount() > 1 // error ::bOnClick := NIL ELSEIF Pcount() == 1 IF HB_isBlock( bValue ) // check parameter type to avoid chaos ::bOnClick := bValue ELSE // Generate error and/or ::bOnClick := NIL // must remove old codeblock return NIL ENDIF IF ::lCreated .and. hb_isblock( ::bOnClick ) // force disconnect, ignore return value ::oQTObject:DisConnect( "clicked()" ) // connect if ! ::oQTObject:Connect( "clicked()" , ::bOnClick ) // generate error (some errors already generated by :connect, // if it returns .F. after a :disconnect there may be other problems... ::bOnClick := NIL ENDIF //::lCreated ENDIF RETURN ::bOnClick
Hi Francesco,
source/widget.prg is not available in svn. Kindly commit that too.
Yes, but instead of callingrathinagiri wrote:Yes, that is a nice idea. However, some signals/events are widget specific and on change of one widget is different from on change of another widget.Perhaps we should think about adding [dis]connect methods to class CONTROL
oLabel:oQTObject:connect(....)
we will call directly
oLabel:connect(....)
In this way we may "centralize" all connect/disconnect and:
- check that QT objects has been created
- if needed, store the situation
Sorry sorry sorry....rathinagiri wrote:Hi Francesco,
I can't access svn from work, so can you please commit this code ?
#include "hbclass.ch"
#include "common.ch"
#include "hbqtgui.ch"
CLASS WIDGET FROM CONTROL
DATA cClass INIT "WIDGET"
DATA oCentral INIT NIL
// Methods
METHOD Create
METHOD CentralWidgetOf SETGET
PROTECTED:
METHOD setCentralWidget
ENDCLASS
METHOD setCentralWidget( oWindow ) CLASS WIDGET
IF ::lCreated
oWindow:oQTObject:setCentralWidget( ::oQTObject )
RETURN .T.
RETURN .F.
METHOD CentralWidgetOf( oValue ) CLASS WIDGET
Local o
IF Pcount() == 0
RETURN ::oCentral
ELSEIF Pcount() == 1 .AND. valtype( ::oCentral ) == "U"
::oCentral := oValue
// Protection: we can't reassign multiple Widget to Central Widget
// retrieve current central Widget
o := oValue:oQTObject:centralWidget()
// if returned pointer is not valid (means there is no central widget already set)
// and widget is created
IF ! o:hasvalidPointer() .AND. ::lCreated
::setCentralWidget( oValue )
RETURN .T.
RETURN .F.
METHOD Create() CLASS WIDGET
// Create QT Object and other initialization tasks
IF valtype( ::oContainer ) == 'U'
::oQTObject := QWidget( ::oParent:oQTObject )
::oQTObject := QWidget( ::oContainer:oQTObject )
::oParent:AddData( ::cName , Self )
::oFont := QFont()
// Setting '::lCreated' flag, so, runtime properties can be invoked
::lCreated := .T.
IF ValType( ::oCentral ) != 'U'; Self:CentralWidgetoF := ::oCentral ; ENDIF
// Set Properties And Events
::oQTObject:show()
RETURN Self
Ok Francesco. Thanks. I will update.
Uploaded and verified.
It is really nice Francesco.
I wish to know the following:
1. What would be the width and height of the central widget?
2. Will that in direct relationship with the window width and height?
3. Will it change because of adding/removing toolbar(s)?
Carlos Britos
Hi Francesco, Rathinagirirathinagiri wrote:Uploaded and verified.
Testing the demo3b.prg I have an object (size 100 x 30) over the toolbar buttons and they don't work ok,
I put this to the code at line 62 and seems to work.
::oQTObject:resize( 0, 0 )
::oQTObject:move( 0,0 )
Can you check this please ? Thanks.
1 & 2 & 3: yesrathinagiri wrote: I wish to know the following:
Open Qt Assistant and search "QMainWindow"
Sorry Carlos, I don't understand....to test demo3b you must click on one of the buttons before moving the toolbar.Carlos Britos wrote: Hi Francesco, Rathinagiri
at line 62 you move resize and move L2...
- mimmo-italia
hello,
how can I define a length of characters in a texbox?
Thanks
Thanks
