TELEPHONE INPUTMASK IN A GRID
mexicanto
HELLO EVERYBODY
DIRECTLY TO MY QUESTION
I AM USING A GRID, ONE OF THE FIELDS IN THE DATABASE IS
"CLIENTES->CLI_TE1" TYPE CHARACTER LENGHT 10
SO IS LIKE 1234567890
HOW CAN I DISPLAY THAT FIELD IN A GRID IN THIS FORMAT : (123) 456-7890
IS FOR THE TELEPHONE NUMBER HERE UN U.S.A
I AM VERY VERY NEWBIE IN HMG, I CAME BACK TO PROGRAMING FROM 20 YEARS
WITHOUT PROGRAMING, MY LAST LENGUAGE WAS CLIPPER SUMMER 87
THANK YOU TO ALL YOU, FOR THE RESPONSE, AND FOR THIS PROGRAM
mexicanto
Re: TELEPHONE INPUTMASK IN A GRID
ONE NOTE
I THINK I CAN CONVERT THE FIELD TO NUMERIC
BUT JUST FOR TRAINING, IN CASE I NEED TO PUT MORE
INPUTMASK IN OTHER CHARACTER FIELDS LIKE :
"ABC745HSS3" DISPLAYED IN THE GRID LIKE "ABC-745-HSS3"
MI PRIMER LENGUA ES EL ESPANOL, SOY DE MEXICO, PERO VIVO EN CALIFORNIA, USA
Ciao Mexicanto
I'm not a guru but I think you don't have solution with standard HMG (rel. 3) properties, for some reason.
My answer is based upon TEXTBOX control properties and benefits (COLUMNCONTROLS is a derived definition) and my little experience.
First: you can define and use only one COLUMNCONTROLS property for the same column (see manual)
For this reason you can use (theorically) OR this picture code "(999) 999-999" OR this one "(AAA) AAA-AAA" (see below).
Second: COLUMNCONTROLS picture mask can only control NUMERIC character (see picture code 9) or ALPHABETIC character (see picture code A) but not ALPHANUMERIC character (there isn't "N" or "X" picture code like CA-Clipper). The default picture mask code is " " (space) to enter any character, but you can't use a mask like this "( ) - " (see TEXTBOX control).
Third: with TEXTBOX control and for CHARACTER datatype and INPUTMASK you pay attention to the real lenght of the field.
For these reasons (I think) you must manage data before load into grid and use a generic COLUMNCONTROLS masked picture like {"TEXTBOX", "CHARACTER"} to (only) printout data.
For example: when you explore (and load data) into the grid, you must create a function to do something like this:
Any way, I think you have another problem: when user must enter data.
Little brief about Italy: we have only numeric value for fixed and mobile phone but not a standard formatting rule.
Fixed numbers are (normally) like 0124745264 or 01176842795 while mobile number are 34756377272, 335755252, 376850965. We now that: if the number begin with 0 is a fixed phone else if begin with 3 it's a mobile phone (there are other numbering set often fixed phone). When you call a fixed phone from U.S. you must use this number 039124745264 where 039 is international prefix for Italy and then the number but omitting the first 0 (zero)
At this moment, it is my best answer.
I hope there is someone who can provide a better solution than mine
Best regards
If AllCharOf( cValue ) Are Numeric
Return cNewValue Formatted Like "(999) 999-999"
Else
Return cNewValue Formatted Like "XXX-XXX-XXXX"
Endif
MyForm.Grid.AddItem( {cNewValue} )Little brief about Italy: we have only numeric value for fixed and mobile phone but not a standard formatting rule.
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
mexicanto
ciao
than you very much for the info
i will try the examples, and later on i will publish the results
thanks again for your response
(any time i see something about italy, the images that comes to my mind are "TOTO !!...ALFREDO !!" from cinema paradiso
Try this code for various combinations. Does any of these suit you? This is from /hmg/samples/inputmask.2Second: COLUMNCONTROLS picture mask can only control NUMERIC character (see picture code 9) or ALPHABETIC character (see picture code A) but not ALPHANUMERIC character (there isn't "N" or "X" picture code like CA-Clipper). The default picture mask code is " " (space) to enter any character, but you can't use a mask like this "( ) - " (see TEXTBOX control).
* HMG InputMask Demo
* (c) 2003 Roberto lopez
InputMask String For Character TextBox
9 Displays digits
! Displays Alphabetic Characters (uppercase)
A Displays Alphabetic Characters
(All other characters are included in text in the position indicated
by the mask)
Format String
No Format Stirng Is Allowed For Character TextBox
WIDTH 450 ;
HEIGHT 250 ;
TITLE 'InputMask Demo' ;
DEFINE MAIN MENU
POPUP 'Test'
ITEM 'Get Text_1 Value' ACTION MsgInfo (Form_1.Text_1.Value)
ITEM 'Set Text_1 Value' ACTION Form_1.Text_1.Value := 'GEW-57927/X'
ITEM 'Set Text_1 Focus' ACTION Form_1.Text_1.SetFocus
SEPARATOR
ITEM 'Get Text_2 Value' ACTION MsgInfo (Form_1.Text_2.Value)
ITEM 'Set Text_2 Value' ACTION Form_1.Text_2.Value := '123.456.789-12'
ITEM 'Set Text_2 Focus' ACTION Form_1.Text_2.SetFocus
SEPARATOR
ITEM 'Get Text_3 Value' ACTION MsgInfo (Form_1.Text_3.Value)
ITEM 'Set Text_3 Value' ACTION Form_1.Text_3.Value := '12.345.678'
ITEM 'Set Text_3 Focus' ACTION Form_1.Text_3.SetFocus
SEPARATOR
ITEM 'Get Text_4 Value' ACTION MsgInfo (Form_1.Text_4.Value)
ITEM 'Set Text_4 Value' ACTION Form_1.Text_4.Value := '1234-1234-1234-1234'
ITEM 'Set Text_4 Focus' ACTION Form_1.Text_4.SetFocus
SEPARATOR
ITEM 'Get Text_5 Value' ACTION MsgInfo (Form_1.Text_5.Value)
ITEM 'Set Text_5 Value' ACTION Form_1.Text_5.Value := 'AA-999/9(A-AAA)'
ITEM 'Set Text_5 Focus' ACTION Form_1.Text_5.SetFocus
SEPARATOR
ITEM 'Get Text_6 Value' ACTION MsgInfo (Form_1.Text_6.Value)
ITEM 'Set Text_6 Value' ACTION Form_1.Text_6.Value := '(253) 427 - 7362'
ITEM 'Set Text_6 Focus' ACTION Form_1.Text_6.SetFocus
END POPUP
END MENU
@ 10,10 LABEL label_1 ;
VALUE 'Simple Code:' ;
WIDTH 100
@ 10,120 TEXTBOX text_1 ;
VALUE 'ZFA-17529/Z' ;
INPUTMASK 'AAA-99999/A'
@ 10,290 LABEL label_1b ;
VALUE 'AAA-99999/A'
WIDTH 100
@ 40,10 LABEL label_2 ;
VALUE 'Brazil ID:' ;
WIDTH 100
@ 40,120 TEXTBOX text_2 ;
VALUE '123.456.789-12' ;
INPUTMASK '999.999.999-99'
@ 40,290 LABEL label_2b ;
VALUE '999.999.999-99'
@ 70,10 LABEL label_3 ;
VALUE 'Argentina ID:' ;
WIDTH 100
@ 70,120 TEXTBOX text_3 ;
VALUE '12.123.123' ;
INPUTMASK '99.999.999'
@ 70,290 LABEL label_3b ;
VALUE '99.999.999'
@ 100,10 LABEL label_4 ;
VALUE 'Credit Card:' ;
WIDTH 100
@ 100,120 TEXTBOX text_4 ;
WIDTH 150 ;
VALUE '1234-1234-1234-1234' ;
INPUTMASK '9999-9999-9999-9999'
@ 100,290 LABEL label_4b ;
VALUE '9999-9999-9999-9999' ;
WIDTH 160
@ 130,10 LABEL label_5 ;
VALUE 'Complex Code:' ;
WIDTH 100
@ 130,120 TEXTBOX text_5 ;
WIDTH 130 ;
VALUE 'JZ-123/4(X-DKS)' ;
INPUTMASK 'AA-999/9(A-AAA)'
@ 130,290 LABEL label_5b ;
VALUE 'AA-999/9(A-AAA)'
@ 160,10 LABEL label_6 ;
VALUE 'Phone Number:' ;
WIDTH 100
@ 160,120 TEXTBOX text_6 ;
WIDTH 130 ;
VALUE '(651) 384 - 8372' ;
INPUTMASK '(999) 999 - 9999'
@ 160,290 LABEL label_6b ;
VALUE '(999) 999 - 9999'
CENTER WINDOW Form_1
mexicanto
thanks rathi
but the problem is, that i want the mask in a grid, with a numeric field
i overcome the problem, just change the field to a character, and then, in an textbox, in the capture time
put the inputmask
thank to all you
anyway, i have 3 questions, or consulting from you
1.- how to capture an image from a web cam, and store it in a field in a database
2.- how to capture a fingerprint from a fingerprint reader and store it in a database, and later on check it
(is for a employee time card checking, lite a time clock), the example is for the employee to put the finger
in the fingerprint reader, and the program "check in" or "check out" the employee to later on print a time assistance
computing the hours worked
3.- how to scan a document and store it in a data base, like id, or social security cards
all are almost the same
does anyone have a code for that ?
thank you very much in advance
put the inputmask
thank to all you
Hi guys,
"Cinema Paradiso" it's a beatiful movie; I think: every young person or child should watch
About other problems, I do not have sufficient knowledge.
Just think, having to store images, there are two possibilities: either store the path of the image file or save the file in a field. In the latter case, I have a question: dbf or another?
Rathi, I hope my explanation it's clear and good
What do you think
About original request, theoretically, he had need two formats because he could have different values (letters or numbers) contained in the same character field (I add: sometime can be a mixture).
Problem: for every coloumn I can define only one columncontrols mask.
I think it would be useful to have an alphanumeric picture code ("X" or "N" like like in CA-Clipper) to printout a mix of characters.
Example. Mask "(XXX) XXX-XXXX" I can printout: "(123) 456-7890", "(aBc) dEf-gHij" and "(1B3) c56-H89j".
Do you think there will be, in the new version of HMG, the possibility of entering a code mask similar to what I presented?
This it's a code for Mexicanto
MEMVAR _HMG_SYSDATA
main function
FUNCTION main()
SET CENTURY ON
SET DATE FORMAT "yyyy/mm/dd"
DefineForm()
ACTIVATE WINDOW ALL
define form
STATIC FUNCTION DefineForm()
LOCAL aCol1 := {"TEXTBOX", "CHARACTER"}
LOCAL aCol2 := {"TEXTBOX", "NUMERIC", "999,999.99", "999,999.99"}
LOCAL aCol3 := {"TEXTBOX", "CHARACTER"}
LOCAL aCol4 := {"TEXTBOX", "DATE"}
LOCAL aCol5 := {"TEXTBOX", "CHARACTER", "(999) 999-9999"}
LOCAL aCol6 := {"TEXTBOX", "CHARACTER", "(999) 999-9999"}
LOCAL aGridHdr := { "Alphabetic", "Numeric", "AlphaNum", "Date", "NumForm", "NumForm2" }
LOCAL aGridWdt := { 100, 100, 100, 100, 100, 100 }
LOCAL aGridCls := { aCol1, aCol2, aCol3, aCol4, aCol5, aCol6 }
LOCAL aGridJst := { GRID_JTFY_LEFT, GRID_JTFY_RIGHT, GRID_JTFY_LEFT, GRID_JTFY_CENTER, GRID_JTFY_LEFT, GRID_JTFY_LEFT }
LOCAL aGridOrd := { { || ChgOrd(1)}, { || ChgOrd(2)}, { || ChgOrd(3)}, { || ChgOrd(4)}, { || ChgOrd(5)}, { || ChgOrd(6)} }
SET NAVIGATION EXTENDED
DEFINE WINDOW MaiFrm ;
ROW 0 ;
COL 0 ;
WIDTH 750 ;
HEIGHT 555 ;
WINDOWTYPE MAIN ;
TITLE "Input test" ;
SYSMENU .T. ;
ON INIT MaiFrm_OnInit() ;
FONTNAME "Arial" FONTSIZE 10
DEFINE TEXTBOX Field1
ROW 30
COL 20
HEIGHT 25
WIDTH 150
INPUTMASK "999,999.999"
TOOLTIP "Numeric"
ONENTER DsplInfo1()
DATATYPE NUMERIC
END TEXTBOX
DEFINE LABEL lb1
ROW 30
COL 200
VALUE "Mask '999,999.999', DATATYPE NUMERIC declared. Without this you can't digit '.'"
WIDTH 500
HEIGHT 30
END LABEL
DEFINE TEXTBOX Field2
ROW 90
COL 20
HEIGHT 25
WIDTH 150
INPUTMASK "(999) 999-9999"
TOOLTIP "Numeric U.S. phone number"
ONENTER DsplInfo2()
END TEXTBOX
DEFINE LABEL lb2
ROW 90
COL 200
VALUE "Mask '(999) 999-9999', no DATATYPE declared."
WIDTH 500
HEIGHT 30
END LABEL
DEFINE TEXTBOX Field3
ROW 150
COL 20
HEIGHT 25
WIDTH 150
INPUTMASK "(AAA) AAA-AAAA"
TOOLTIP "Character U.S. phone number"
ONENTER DsplInfo3()
END TEXTBOX
DEFINE LABEL lb3
ROW 150
COL 200
VALUE "Mask '(AAA) AAA-AAAA', no DATATYPE declared."
WIDTH 500
HEIGHT 30
END LABEL
DEFINE TEXTBOX Field4
ROW 210
COL 20
HEIGHT 25
WIDTH 150
TOOLTIP "Free textbox"
ONENTER DsplInfo4()
DATATYPE CHARACTER
END TEXTBOX
DEFINE LABEL lb4
ROW 210
COL 200
VALUE "No Mask, DATATYPE CHARACTER declared."
WIDTH 500
HEIGHT 30
END LABEL
DEFINE GRID grid1
ROW 270
COL 20
WIDTH 650
HEIGHT 200
HEADERS aGridHdr
WIDTHS aGridWdt
COLUMNCONTROLS aGridCls
JUSTIFY aGridJst
ONHEADCLICK aGridOrd
END GRID
OnInit event
STATIC FUNCTION MaiFrm_OnInit()
MaiFrm.Center
LoadDataIntoGrid()
MaiFrm.Field3.Value := "(ABC) DEF-GHIJ"
display information about Field1
STATIC FUNCTION DsplInfo1()
MSGSTOP( "ValType is " + VALTYPE( MaiFrm.Field1.Value ) )
IF VALTYPE( MaiFrm.Field1.Value ) == "C"
MSGSTOP( "Len is " + HB_VALTOEXP( LEN( MaiFrm.Field1.Value ) ) )
MSGSTOP( "Value is " + MaiFrm.Field1.Value )
MSGSTOP( "Value is " + HB_VALTOEXP( MaiFrm.Field1.Value ) )
display information about Field2
STATIC FUNCTION DsplInfo2()
MSGSTOP( "ValType is " + VALTYPE( MaiFrm.Field2.Value ) )
IF VALTYPE( MaiFrm.Field2.Value ) == "C"
MSGSTOP( "Len is " + HB_VALTOEXP( LEN( MaiFrm.Field2.Value ) ) )
MSGSTOP( "Value is " + MaiFrm.Field2.Value )
MSGSTOP( "Value is " + HB_VALTOEXP( MaiFrm.Field2.Value ) )
display information about Field3
STATIC FUNCTION DsplInfo3()
MSGSTOP( "ValType is " + VALTYPE( MaiFrm.Field3.Value ) )
IF VALTYPE( MaiFrm.Field3.Value ) == "C"
MSGSTOP( "Len is " + HB_VALTOEXP( LEN( MaiFrm.Field3.Value ) ) )
MSGSTOP( "Value is " + MaiFrm.Field3.Value )
MSGSTOP( "Value is " + HB_VALTOEXP( MaiFrm.Field3.Value ) )
display information about Field4
STATIC FUNCTION DsplInfo4()
MSGSTOP( "ValType is " + VALTYPE( MaiFrm.Field4.Value ) )
IF VALTYPE( MaiFrm.Field4.Value ) == "C"
MSGSTOP( "Len is " + HB_VALTOEXP( LEN( MaiFrm.Field4.Value ) ) )
MSGSTOP( "Value is " + MaiFrm.Field4.Value )
MSGSTOP( "Value is " + HB_VALTOEXP( MaiFrm.Field4.Value ) )
Load data into grid
STATIC FUNCTION LoadDataIntoGrid()
MaiFrm.grid1.AddItem( {"aBcDeFgH", 123.45, "3C7OU6", DATE(), 1234567890, "(123) 456-7890" } )
MaiFrm.grid1.AddItem( {"d Value", 12354.67, "4Bc3oN3", DATE()-10, 4508123796, "(450) 812-3796" } )
MaiFrm.grid1.AddItem( {"b Value", 543567.12, "2I5rh34", DATE()-20, 1357908642, "(135) 790-8642" } )
Change Order
STATIC FUNCTION ChgOrd( nOrder )
LOCAL aTemp := {}
LOCAL nX
FOR nX := 1 TO MaiFrm.grid1.ItemCount
AADD( aTemp, MaiFrm.grid1.Item( nX ) )
NEXT nX
aTemp := ASORT( aTemp,,,{|a,b| a[nOrder]<=b[nOrder]} )
MaiFrm.grid1.DeleteAllItems
FOR nX := 1 TO LEN( aTemp )
MaiFrm.grid1.AddItem( aTemp[nX] )
NEXT nX
MaiFrm.grid1.Value := 1
RETURN NILLuigi from Italy
www.L3W.it
www.L3W.it
Hmm. That we have to think of Luigi.
mexicanto
cinema paradiso, thief of bicycles, etc etc etc
guiseppe tarnatore, ennio morricone, the perfect combination
india...bollywood..."childens of heaven"..
as you can see, i like foreing movies, i think i will start a topic in the "off topics" area about "movies from my country that you have to see", there, you can recomend me movies from your contry
back to the question
i solve my main problem, following the examples in "contactos" samples, thanks again for your cooperation
for the other 3 request:
if someone have a code, or want to write the code and the library, i am willing to pay (sorry, will be in american dollars, wire transfer) for that task that i need
just have to follow this directions :
ability to store the scan, capture image, and use the fingerprint in the database, not in a external file
the code will be use it in different programs, for different purposes,so no royalty fees for the each machine or program i will use it
i need the source code
full of explanation, because i am coming back from clipper summer 87, not ca-clipper, so i am a very beginner in the gui interfase, i still learning about methods, properties, etc
if somebody is interested in this project, just let me know how much are going to ask fot that (the price)
thabk you very much for you time and patience with me
atte
daniel gaitan (mexicanto)
atte
Hi Rathi,
I'm sorry but I don't understand your replay or I write a bad English.
When I ask to you "What do you think" I'm referring to my contribute not to me
In too many forum I find people who answer without give a good contribute and when I writed
"you don't have solution with standard HMG (rel. 3) properties" I hope don't write a mistake
Best regards (IT: migliori saluti) but I prefer Ciao.
Luigi from Italy
www.L3W.it
www.L3W.it
