Line 01 MEMVAR _HMG_SYSDATA
Line 02
Line 03 #include "hmg.ch"
Line 04
Line 05 FUNCTION main()
Line 06
Line 07 LOCAL cLocalVar := ""
Line 08
Line 09 cLocalVar := GetCurrentFolder()
Line 10
Line 11 MSGSTOP( cLocalVar )
Line 12
Line 13 RETURN NIL
Line 14
Line 15 FUNCTION Other()
Line 16
Line 17 LOCAL cLocalVar
Line 18
Line 19 cLocalVar := GetCurrentFolder()
Line 20
Line 21 MSGSTOP( cLocalVar )
Line 22
Line 23 RETURN NIL
This is the message IF the source is compiled with warning level 3
hbmk2: Processing configuration: D:\HMG\MiniGui\harbour\bin\hbmk.cfg
Harbour 2.0.0 (Rev. 13372)
Copyright (c) 1999-2010, http://www.harbour-project.org/
hbwarntest.prg(15) Warning W0032 Variable 'CLOCALVAR' is assigned but not used in function 'MAIN(7)'
If I set warning level to zero no message displayed (of course)
As you can see, in one case raises the alert while the other not.
(without assigned value); only the first row give me warning
Any way many thanks.
Hi l3whmg
Is the normal Harbour behaviour of switch -w3
If you assign the "" to cLocalVar and later in the code assign another value then the first assignement is unused, but if you set LOCAL cLocalVar := "" and later use: cLocalVar += "something" then there is no warning.
Nice explanation Carlos. Thanks.
East or West HMG is the Best. South or North HMG is worth.
Hi Carlos, many thanks for you answer.
I had sensed this "behaviour" but I was hoping there was an alternative.
Any way, I will try to align the source code to this rule.
Many thanks
