Senddata Getdata
Senddata Getdata
Hola a Todos:
estoy intentando implementar Senddata y Getdata desde aplicaciones HMG
hay algun ejemplo estas Funciones? ya que al tratar de implementar esas funciones me da error.
recuerdo que la aplicacion que envia datos se cierra despues y la aplicacion que recibe cienpre esta abierta.
Google Translate
Hi Everyone:
I'm trying to implement SendData and HMG Getdata from applications
is there any example of these functions? because when trying to implement these functions gives me error.
I remember the application that sends data and closes after receiving the application is always open.
Re: Senddata Getdata
Hola Daniel,
Conseguistes algun ejemplo ? Encontré este aqui:
#include "minigui.ch"
	REQUEST HB_GT_WIN_DEFAULT
    LOCAL title:='Harbour MiniGUI Demo'
    SET STATIONNAME TO "MAINPROC"
	_HMG_Commpath:= GetCurrentFolder()+"\"
		WIDTH 640 HEIGHT 480 ;
		TITLE title ;
		MAIN ;
		FONT 'Arial' SIZE 10;
		ON INIT ConsoleInit(title)
		DEFINE LABEL Label1
			ROW 10
			COL 10
			VALUE "Good morning"
		END LABEL
		DEFINE TEXTBOX Box1
			ROW 10
			COL 100
			WIDTH  60
			HEIGHT 24
			VALUE "    5"
			NUMERIC .F.
		END TEXTBOX
		DEFINE BUTTON Btn1
			ROW 50
			COL 10
			CAPTION 'Press me'
			ACTION {||FN1(), SetProperty("Form_1","Box1","Value",GetData())}
		END BUTTON
		DEFINE BUTTON Btn2
			ROW 100
			COL 10
			CAPTION 'Message'
			ACTION FN2(Form_1.Box1.value)
		END BUTTON
		DEFINE BUTTON Btn3
			ROW 150
			COL 10
			CAPTION 'EXIT'
			ACTION Form_1.release
		END BUTTON
	Form_1.Center()
	Form_1.Activate()
FUNCTION FN1()
HIDE WINDOW Form_1
ShowConsole()
CLEAR SCREEN
r1 := "0000"
r2 := "0000"
@ 10,10 SAY ' S1 ' get r1 pict '9999'
@ 12,10 SAY ' S2 ' get r2 pict '9999'
read
HideConsole()
RESTORE WINDOW Form_1
SHOW WINDOW Form_1
SendData("MAINPROC",r2)
FUNCTION FN2(n)
LOCAL i
N:=VAL(n)
HIDE WINDOW Form_1
ShowConsole()
CLEAR SCREEN
FOR i:=1 TO n
    ? "i= ",i
WAIT
HideConsole()
SHOW WINDOW Form_1
MsgBox('Box1 value is '+TRANSFORM(n,'99'),'Test')
FUNCTION ConsoleInit(title)
SetConsoleTitle(title)
HideConsole()
* embeded C code
* can be put in separate .c file (without #pragma of course)
#pragma BEGINDUMP
#include "hbapi.h"
#include "hbapiitm.h"
#include <windows.h>
// doesn't work with win32 function GetConsoleWindow()
HWND GetConWin()
HWND nH;
char realtitle[ MAX_PATH ];
GetConsoleTitle( realtitle,MAX_PATH );
SetConsoleTitle( "Finding Handle" );
nH=( HWND) FindWindow( NULL,"Finding Handle" ) ;
SetConsoleTitle( realtitle );
return nH;
HB_FUNC( GETCONSOLEWINDOW )
hb_retnl((long) GetConWin() );
HB_FUNC(HIDECONSOLE )
ShowWindow(GetConWin(),SW_MINIMIZE); // SW_HIDE
HB_FUNC(SHOWCONSOLE )
ShowWindow(GetConWin(),SW_RESTORE); //SW_SHOW
ShowWindow(GetConWin(),SW_SHOW); // because 1'st time console stays minimized
HB_FUNC(SETCONSOLETITLE)
{ char * szTitle=hb_parc(1);
SetConsoleTitle(szTitle);
#pragma ENDDUMP
Pero está dando este error:
Hola Pablo:
estaba mirando Send/Get Data porque necesitaba enviar un dato entre aplicaciones , ya que mi aplicacion necesita comunicarse con otras que verdaderamente es el mismo desarrollo y en este caso esta separado de la aplicacion principal.
Antes hablamos de los años 90 y pico.. era parte del mismo programa.
Ahora se componen de diferentes modulos que se pueden usar separados. una solucion un poco sucia fue utilizar archivos de texto para intercambiar datos.
Ahh bueno, pensé que habias concluído algo sobre SendData e GetData. Yo seguiré intentando. Todo esto es para mi aprendizado y comovi tu mensaje sin respuesta quise exponer lo que tengo. Gracias por responder, un grande abrazo.
Senddata Getdata
Passed a quite long time... but finnaly I backed to this matter.
Now with some more HMG knowledge in my small luggage ! :D
This error happen because in the previous code sample was missing COMMPATH definition.
In HMG instead of Minigui Extended we need to define thru SET COMMPATH TO command.
  • So added SET COMMPATH TO command.
  • There was also an hard execution when trying to the button EXIT. I replaced Form.Release by TerminateProcess()
  • Some other functions was added like: SetForegroundWindow and SetConsoleTitle.
  • Replace SW_MINIMIZE property by SW_HIDE for console opend session
  Based on Grigory MixedMode demo
  Adapted version for HMG
  By Pablo César Arrascaeta
  On February 23rd, 2015
Function Main()
Local title:='Harbour MiniGUI Demo'
SET COMMPATH TO GetCurrentFolder()+"\"
	TITLE title+" - GUI" ;
	MAIN ;
	ON INIT ConsoleInit(title+" - Console")
	DEFINE LABEL Label1
		ROW 10
		COL 10
	END LABEL
	DEFINE TEXTBOX Box1
		ROW 10
		COL 100
		WIDTH  60
		HEIGHT 24
		VALUE "    5"
		NUMERIC .F.
	END TEXTBOX
	DEFINE BUTTON Btn1
		ROW 50
		COL 10
		CAPTION 'Press me'
		ACTION {||FN1(), SetProperty("Form_1","Box1","Value",AllTrim(Str(GetData())))}
	END BUTTON
	DEFINE BUTTON Btn2
		ROW 100
		COL 10
		CAPTION 'Message'
	END BUTTON
	DEFINE BUTTON Btn3
		ROW 150
		COL 10
		CAPTION 'EXIT'
		ACTION TerminateProcess() // Form_1.release
	END BUTTON
Form_1.Center()
Form_1.Activate()
FUNCTION FN1()
HIDE WINDOW Form_1
ShowConsole()
CLEAR SCREEN
r1 := 0
r2 := 0
read
HideConsole()
Form_1.Restore
Form_1.Show
SetForegroundWindow(Form_1.Handle)
Form_1.Box1.SetFocus
FUNCTION FN2(n)
LOCAL i
N:=VAL(n)
HIDE WINDOW Form_1
ShowConsole()
CLEAR SCREEN
FOR i:=1 TO n
    ? "i= ",i
WAIT
HideConsole()
Form_1.Restore
Form_1.Show
HideConsole()
* embeded C code
#pragma BEGINDUMP
#define COMPILE_HMG_UNICODE
#include "HMG_UNICODE.h"
#include "hbapi.h"
    HWND hwnd;
    hwnd = FindWindowA("ConsoleWindowClass",NULL);
    ShowWindow((LONG) hwnd, SW_HIDE);                // SW_MINIMIZE
    HWND hwnd;
    ShowWindow((LONG) hwnd, SW_RESTORE);           // SW_HIDE
    ShowWindow((LONG) hwnd, SW_SHOW);              // because 1'st time console stays minimized
	SetForegroundWindow ( hwnd );
{  char * szTitle=HMG_parc(1);
#pragma ENDDUMP
Now is working in HMG and was clear out this question.
I hope you enjoy it ! :D
Gracias Pablo, como te decia antes deje de lado GET/Senddata y funciona con archivos de text para el intercambio de datos y no me genera problemas,
por cuestiones de tiempo no voy a implementar esas 2 funciones
igualmente gracias por el aporte a la comunidad.
Post by EduardoLuis »
Hi Dany and Pablo:
Between developing a complex system with many separate modules (exes) i had the same problem; the solution i get simple but effective was creating a .MEM file with the variables & it's contents, where all vars have previously defined on any appe (same name and size); this *.mem files is allways upgraded by different modules, and is really quick.- As you implement .TXT, the result will be the same.-
IMHO SEND/GET data goes perfect inside the same app, but between different modules a .MEM files is more sure and also quick.- In some cases if .MEM contents it's critical, after been read by and specific app, the last app erase o rewrites .MEM whit a different contents.-
This solutionw works fine for me.- This could be a good option for you also.-
With regards. Eduardo
Hola Dany y Pablo:
Mientras desarrollaba un complejo sistema con muchos modulos (EXES) tuve el mismo inconveniente; la solución a la que llegué fue simple y efectiva, crear un archivo .MEM conteniendo variables y sus contenidos, donde todas esas variables fueron previamente definidas en cada aplicación (mismo nombre y tamaño); este archivo .MEM se actualiza automaticamente en cada modulo, y lo hace realmente rápido.- Como tu has implementado .TXT el resultado es el mismo.-
En mi opinión SEND/GET DATA se aplica mas dentro de una misma aplicción, pero entre diferentes módulos, el archivo .MEM me parece mas seguro y rapido.- En algunos casos si el archivo .MEM contendrá información crítica, despues de haber sido leido su contenido, la ultima aplicación lo borra o re-escribe con un diferente contenido.-
Esta solución ha funcionado perfectamente para mi. Esta podría ser una buena opción para ti.-
Cordialmente. Eduardo.-
Senddata Getdata
Gracias Daniel y Eduardo por el interés y sus indicaciones.
Volví a este tema, porque estaba pendiente y antes no lograba hacerlo funcionar.
Pero está aqui, sirve como aprendizaje.
Gracias por compartir!
