Hi Team!
Thanks to Viktor and Pritpal from Harbour team, that helped me to solve some problems, we are in Linux too!
This is the grid demo_1:
Wonderful :D
Thanks Maestro
Hi Team!
Please, be careful wit case, since it is relevant in linux, so, keep the #includes and filenames in lowercase.
Another important thing is to use slashes instead backslashes.
ie:
The following works in Windows but not in Linux:
Set Procedure To ..\..\source\window
The following work in both:
Set Procedure To ../../source/window
Thanks.
It looks great Roberto. I am very happy about HMG becoming platform independent.
Again thanks for your info.
rathinagiri wrote:Also I could not make demo_2.prg run by changing hmg.ch. It shows some # translate errors which I could not trace out. :(
I've fixed and committed the changes.
Preprocessor directives are case sensitive. That was the problem.
Thanks for the fix Roberto. I will note down. :)
So, now can I start working on Tree?
rathinagiri wrote:Thanks for the fix Roberto. I will note down. :)
No problem!
I've finished the works on mainmenu, toolbar and tab.
TODO.TXT and EXTENSIONS.TXT updated.
Hi Team,
I'll start print system.
sudip
Post by sudip »
Roberto Lopez wrote:
sudip wrote:Hello,
Till now I cannot solve inputmask problem of textbox control fully. Inputmask (especially for numeric data types) is behaving differently. I can't solve the decimal point problem.
Please help me.
When I find something that is not directly supported by QT, I'm tagging as TODO and move to other thing, since I guess that in this stage of development is better to invest our time and energy on having more controls working.
ie: maxlength is not supported by QTextEdit (editbox) so, I've delayed to the next stage.
Hopefully, we will have a better knowledge about QT in the future to revisit this undone things to complete them.
Thanks a lot Roberto :)
I shall try for another control.
I think Timer, RichEditbox, Slider controls are free.
Can you please suggest any control for me :)
