To who standing in front of the wall
Maciek wrote:
So, now I'm just standing in front of the wall and got no idea what I did wrong if - in fact - I literally did nothing; just updated HMG).
So if could help - please help! I'm completly HMG newbie. With harbour I work since a year and with clipper since 1991 (with 6 years break).
In elder version of HMG, I found in a firm I work for (HMG: Harbour MiniGUI 1.0 (Build 108) - 2005.08.21, IDE: Harbour MiniGUI IDE 1.0 Build 016 - 2005.06.17) all works well.
With HMG.4 and HMG.OBJECTS I didn't work yet, so i got three questions: is there any manual for completly newbe? Does these ones comes with IDE? Where to start from with e.g. HMG.4?
Sincerely
Maciek Ciechoński
Hello Maciek
First, welcome aboard,
greeting from Turkiye :)
Second, please don't panic, here you are between friends :D
And third :
HMG.4 is a continuation of HMG OBJECTS and is in alpha (development) phase, not finished yet.
So you have download and use HMG 3.035, last stable version on HMG, from here.
This is a complete package, including IDE and documentation (yes, very helpful for newbies too :) ).
Maciek
Re: To who standing in front of the wall
Post by Maciek »
Hi esgici!
Ok. No panic (done), get 3.035 (in progress), read docs (ToDo).
Thank You very much!
Maciek
Maciek wrote: OK. Now I've just installed c:\hmg.3.035 and then made dir \proj\rampdf where
i got a project to be corrected. It consists of 2 prgs only, no forms or so.
After build i got an error:
hbmk\win\mingw\pdf.o:pdf.c:(.data+0x848): undefined reference to `HB_FUN_TREG32'
Lines in code (pdf.prg):
oReg := TReg32():New( HKEY_CLASSES_ROOT, cExt, .f. )
What to do?
Hi Maciek
As far as know there isn't a function named TREG32 in HMG nor Harbour :(
Probably you got this prg from another source.
I don't know you are aware or not, MiniGUI Extended and HMG are two separate projects.
I remember, in our forum some .pdf based discussions past. By using search feature of forum, I hope you will find some hints or helps.
By the way, working on special file formats like .pdf, isn't a bit high concepts for a newbie ?
In my humble opinion, beginning as far as simple samples will be better way for learning.
Maciek
Post by Maciek »
esgici,
I got two prg files: rampdf.prg and pdf.prg. They both forms whole project.
In rampdf.prg (main module) i got main routine. There was 1 problem with it:
it included line "set procedure to pdf", so after first build with hmg3.35 I got list of information, e.g.
.hbmk\win\mingw\pdf.o:pdf.c:(.text+0x0): multiple definition of `HB_FUN_GETDEFAULTPRN'
.hbmk\win\mingw\rampdf.o:rampdf.c:(.text+0x0): first defined here
.hbmk\win\mingw\pdf.o:pdf.c:(.text+0x280): multiple definition of `HB_FUN_GETOPENCOMMAND'
.hbmk\win\mingw\rampdf.o:rampdf.c:(.text+0x2a0): first defined here
etc., so I removed line "set procedure to pdf", and after build there was left only this error meesage mentioned before.
This prg contains functions I don't know of which lib, if any... I'll send i to You, ok?
As for now I found Treg32() is a part of TREG class found in FiveWin... But I don't see over here (in my folders) any fivewin libs.
Strange thing is why that code compiles with old version of minigui and with new one generates an error.
Ha! I found a .bat file containg... looks like a script or what? I'll link it too, ok?
Thanks for the info about a difference between HMG and MiniGUIExtended - I just was not sure of that! :)
Of course I want to use HMG project in a way it's intended for, but *now* I *have to* make some changes to the code fellows made years ago and which lines first time I saw few hours ago, so...here's the catch.
Thanks in advance
Maciek
PS Attachement included: pdf_problem.zip, contains: -pdf.ch, pdf.prg, pdf.bat
pdf_problem.zip
(20.02 KiB) Downloaded 258 times
Maciek wrote: ...
Maciek,
Most probably this is a MiniGUI Extended project, and sadly, I haven't sufficient knowledge about it :(
Relation between this two versions (there are more version of HMG), isn't one is older and other is newer; both are advancing in parallel and growing away from each other. So any project compiled in one of them may not compile-able with other, this is a normal result.
Regarding FiveWin, as far as I know it's a commercial product and HMG haven't any lib for it.
My humble suggestion is: please forget this job for now. Begin learning HMG at the beginning. After a very short time I'm sure that you will write your own pdf prg by starting from the scratch :)
PS: By the way, this is weekend and most of our friends is out of forum (some of them prefers real friends to virtual ones ;) ). After Sunday may come a friend expert in MiniGUI extended, and may help you.
Hello Maciek!
I think you should wait for Grigori Filatov, who is expert and one of the authors of HMG Extented.
Maciek
Post by Maciek »
Hi esgici and Marek!
Thanks for Your infos and advices! I think it's really better to me to know HMG from scratch and so i'll do.
I thought if i get old version of HMG and that code links with it well, I'll just make necessary changes and use old HMG for just that pdf stuff.
Maciek
PS I've left a hanging session on this forum on saturday, so if it's not allowed here - I apologize. Just had to leave in a hurry.
