Roberto Lopez wrote:
mol wrote:I'm still lerning QT and reading documentation.
IMAGE is realized, maybe not ended, but working with PNG images.
I think, I can take next control to create. Please assign me next job!
Ok.
I guess that Combobox is free, so you could work on it.
You could need to synchronize your work with rathinagiri, sin he is working on listbox and maybe you can share code for some properties.
OK. I'm taking it!
Ok.
OK. I'm taking it!
Ok. I'll take image.
Roberto Lopez wrote: Then go to label samples folder, copy on it the hmg.gif file and compile the demo_1.
hmg.gif, will be show instead label text.
So, gifs are directly supported.
The same applies to .jpg files.
I've changed references to hmg.gif by hmg.jpg and works perfectly.
Maybe something is wrong with my computers???
Maybe something is wrong with my mind :(
I've just changed such two lines on label and all my labels become images (png,gif, jpg and .bmp).
I'll upload a complete image class soon, so you can check it.
I've completed IMAGE class, too.
I only need to clean up code
Marek
sudip
Post by sudip »
Hello,
TextBox can now store different DataTypes. I tested it. It runs fine (except, the "/", "." characters can be deleted, and no restriction for datatype specific input :( ). I think it's better to post here first for your check before SVN Commit
METHOD Value (xValue) CLASS TEXTBOX
   If Pcount() == 1
      Do Case
         Case ValType(xValue) == "N"
            xValue := Str(xValue)
         Case ValType(xValue) == "D"
            xValue := Dtoc(xValue)
      EndCase
   Endif
	If ::lCreated
      If Pcount() == 0
			RETURN If(::DataType == TXT_NUMERIC, ;
            Val(::oQTObject:Text()), ;
               If(::DataType == TXT_DATE, CToD(::oQTObject:Text()), ::oQTObject:Text()))
		ElseIf Pcount() == 1
			::oQTObject:SetText(xValue)
		EndIf
	Else
      If Pcount() == 0
			RETURN ::xValue
			::xValue := xValue
		EndIf
	EndIf
METHOD DataType ( nValue ) CLASS TEXTBOX
// DataType is not a property of QLineEdit
   If Pcount() == 0
		RETURN ::nDataType
		::nDataType := nValue
	EndIf
RETURN Nil
mol wrote:I've completed IMAGE class, too.
Marek
I've uploaded an image class test that works fine with .jpg, gif and bmp.
Please, take a look at it:
I've compiled your IMAGE class and get this on the screen:
So, I don't know, what's going on.
I've deleted my HMG.4\svn\samples and HMG.4\svn\source folders. Then I've updated these folders from SVN, recompiled samples\image\demo_1.prg and nothing better happened :(
Maybe the rest of the team could test this sample?
It's very strange - it does not work on my three computers two with XP and one with win'7.
I too get the demo screen just like Marek.
And, when I changed all the pictures to 'hmg.bmp', all the three come up.
It looks like only .bmp files are working.
On my computers sample works good with png and bmp images. I think, basic is JPG at now and it must work.
