How do I add a Close button in editbox and other similar objects?
Or, is it possible to add something like: On Escape, close object?
Also, how do I hide cursor in an editbox (created as readonly)?
Once again, thank you for the help.
Editbox and other objects
Re: Editbox and other objects
The original post did not get a reply, so please allow me to re-phrase my question.
In a form, there is an editbox object. After reading, how do users close the editbox (since there is no Close button)? In the program, I cannot issue a Release statement because there is no trigger.
So, I tried this:
@ 10, 10 EDITBOX ebRein ;
PARENT MainForm ;
WIDTH 300 ;
HEIGHT 300 ;
VALUE "Reindexing files..." + CRLF ;
ON GOTFOCUS ReinQuit();
READONLY
function ReinQuit()
// quit editbox if escape is pressed by user
if lastkey() == K_ESC
MainForm.ebRein.Release
return NIL
It did not work. What I was trying to do was:
if object has focus, check if last keypressed is ESC.
If yes, then close object.
Any idea how to do it?
All I want is allow the user to close the editbox.
Please help. TYVM.
So, I tried this:
PARENT MainForm ;
WIDTH 300 ;
HEIGHT 300 ;
READONLY
function ReinQuit()
return NIL
Please help. TYVM.
LASTKEY does not work in GUI.
You can add:
or
You can add:
ON KEY ESCAPE OF MainForm ACTION ReinQuit()
ON KEY ESCAPE OF MainForm ACTION MainForm.ebRein.Release
It worked! Thank you very much, Marek.
Is this the only way to allow the user to close an object?
Is it not possible to add a Close button (X) at the top-right part?
This editbox is a progress window for indexing files. While indexing is going on, I pressed Esc. It did close the editbox window but the indexing process did not terminate prematurely (thankfully!).
Thanks again, Marek, you've been a very big help to me.
You can use standalone button and set its action to release editbox.
I'm glad to help you!
Marek
Marek
Thanks, Marek, for the suggestion.
