Yep I agree 100%. I liked your approach to the 3.x IDE. Already starting work on it? Wow. Great to hear that. I'm too spoiled by Delphi to go back to writing code for controls (I only made an exception with PHP but well, that's HTML anyway)Roberto Lopez wrote:Anyway, IMHO HMG4 should have its own IDE consistent with HMG philosophy: very simple and easy to use.Roberto Lopez wrote:I've provided a batch file for build samples to keep the things simple, but, it could be included in future binary releases.apais wrote:Why don't you use hbIde ? It's done with harbour and qt and is multiplatform also.
The works on it, could start when adequate functionality be in place.
Coding Guidelines For HMG 4 Contributors [UPDATED]
Re: Coding Guidelines For HMG 4 Contributors [UPDATED]
Charly
Argentina, Hobbyist developer, Clipper/Delphi/PHP/Progress
- Roberto Lopez
- HMG Founder
Todos debemos nos vemos obligados a usar PHP más de lo que quisiéramoscdsaenz wrote:(I only made an exception with PHP but well, that's HTML anyway)
Nice move. Thanks Roberto
Carlos Britos
[quote=No está en HMG.4 (quité algunos archivos no escenciles para reducir el tamaño de la distribución).[/quote]
Hello Roberto.
I don't know nothing about management of project in sourceforge, but what you think about to put qt, mingw and harbour binaries in zip files in different folders in sourgeforge. so we can get only those files that we really need, reducing the size and traffic. Specially with a bad internet connection.
Saludos y gracias por todo
Carlos
Hello Roberto.
Carlos
- Roberto Lopez
- HMG Founder
Carlos Britos wrote:My goal is to provide a 'ready to use' binary distribution for non-experts.No está en HMG.4 (quité algunos archivos no escenciles para reducir el tamaño de la distribución).[/quote wrote:
Hello Roberto.
Carlos
If you want only sources you can get from SVN section of the project.
I strongly agree with Roberto. The reason, why I am using HMG is, that it was very easy to get running at first.Roberto Lopez wrote: My goal is to provide a 'ready to use' binary distribution for non-experts.
For years I have been looking at harbour-project, but was never able to make it work. Neither on Linux, Mac OS, nor on Windows. I simply thought it was not finished yet. Now I know that harbour is an excellent programming language. It just makes it extremely hard for newbees like me to get startet.
The second reason is this forum, which helps me a lot, because I don't speak spanish. It is the friendliest place in open source development.
The only downside was that the hmg-binaries only run on windows.
Roberto has the right philosophy and now, that it is going multi-platform, hmg has the potential for greatness.
I am afraid, that my programing skills are not good enough for development. But I can do testing on different platforms.
Raumi
Raumi75 http://raumi75.jimdo.com
- Roberto Lopez
- HMG Founder
Thanks for your kind words.raumi75 wrote: Roberto has the right philosophy and now, that it is going multi-platform, hmg has the potential for greatness.
Raumi
And, please consider that QT is very high level compared to Windows API, that it is fully documented and that C programming is not required, so I guess that anyone can do.
I've designed the whole thing to be simple to develop, so, if contributors follow the guidelines, it will still easy...
Hi, all
My humble contribution ; Syntax file for Notepad ++
Ed
Ed
- userDefineLang.7z
- (2.5 KiB) Downloaded 1296 times
- Roberto Lopez
- HMG Founder
Thanks!Steed wrote:Hi, all
Ed
Thanks for notepad++ syntax file. I'm using this editor. I've prepared my syntax file, but it never was ended to share with sb.
