I found problem in \samples\tutorial\tutor20.prg
tutor20.prg(33) Error E0030 Syntax error "syntax error at '@'"Is there any solution?
tutor20.prg(33) Error E0030 Syntax error "syntax error at '@'"Code: Select all
OpenTables()
DEFINE WINDOW Win_1 ;
WIDTH 640 HEIGHT 480 ;
TITLE 'Tutor 20: GRID Test' ;
MAIN NOMAXIMIZE
DEFINE MAIN MENU
POPUP 'File'
ITEM 'Set Grid RecNo' ACTION Win_1.Grid_1.Value := Val ( InputBox ('Set Grid RecNo','') )
ITEM 'Get Grid RecNo' ACTION MsgInfo ( Str ( Win_1.Grid_1.RecNo ) )
SEPARATOR
ITEM 'Exit' ACTION Win_1.Release
END POPUP
POPUP 'Help'
ITEM 'About' ACTION MsgInfo ("Tutor 20: GRID Test")
END POPUP
END MENU
@ 10,10 GRID Grid_1 ;
WIDTH 610 ;
HEIGHT 390 ;
HEADERS { 'Code' , 'First Name' , 'Last Name', 'Birth Date', 'Married' , 'Biography' } ;
WIDTHS { 150 , 150 , 150 , 150 , 150 , 150 } ;
ROWSOURCE "Test" ;
COLUMNFIELDS { 'Code' , 'First' , 'Last' , 'Birth' , 'Married' , 'Bio' } ;
columncontrols {{"TEXTBOX","NUMERIC"},{"TEXTBOX","CHARACTER"},{"TEXTBOX","CHARACTER"},{"TEXTBOX","DATE"},{"CHECKBOX"},{"TEXTBOX","CHARACTER"}};
ALLOWDELETE ;
EDIT
Win_1.Grid_1.RecNo := RecNo()
CENTER WINDOW Win_1
ACTIVATE WINDOW Win_1
Procedure OpenTables()
Use Test
