A new Harbour site
Re: A new Harbour site
Thanks Pete.
I am now using PsPad distributed along with HMG.
swapan
Post by swapan »
Thanks Esgici for starting this topic and sincere thanks to all for the inputs.
Was not aware of such developments.......
Nice boosting words from Pete.....
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
Hola Charly
cdsaenz wrote: ...
The DBU utility looks fine but not fully implemented yet.
Which DBU you are talking about ?
If it's DBA, please let me know your opinions, especially missing features by your point of view.
Every idea is important for development.
sudip
Post by sudip »
esgici wrote:...
By the way, is there anyone tried hbide ?
I am now experimenting with hbide (latest SVN) with help from Massimo.
I shall tell you within 1/2 days.
mbelgrano
Post by mbelgrano »
hbide now include very good a dbu viewer
I plan add updated info at http://harbourlanguage.blogspot.com/
Have samebody here visual foxpro feature
[/quote]
cdsaenz
Post by cdsaenz »
Hi Massimo. Not sure if you're asking me, but I meant ideDBU utility in hbIDE, I couldn't modify the structure (there is a button bar on the left with the same hints all of them but they don't work).
The IDE looks good, liked the theming, and the function list. The File Open dialog is way too slow though; maybe a QT issue. Other than it looks good!
Charly
Argentina, Hobbyist developer, Clipper/Delphi/PHP/Progress
sudip
Post by sudip »
Hello All,
Just now I am able to compile with HBIDE :D
It's an excellent IDE, with more and more features coming :)
Many thanks to Massimo and Pritpal. :)
gvaronas
Post by gvaronas »
[quote="esgici"]Hi All
A new web site / blog about Harbour Language
I couldn't find builder :( (Massimo Belgrano :?: )
Hola Esgici, En la ultima distribución de HMG.OBJECT, en la parte de Harbour viene HbIDE.
Te comento que yo lo he probado y es fantástico, definitivamente es un xMate supermejorado, tiene, entre etras cosas:
- Toda la documentación disponible que la toma desde los fuentes de harbour
- Puedes documentar tus propios PRG
- Buesquedas y remplazos en uno o varios proyectos
- DBU
- Ultimamente se ha puesto un prototipo del Diseñador de reportes
- Ayuda en Linea (Creo que le llaman intellisense o algo asi)
- y mucho mas.
Sin embargo, de momento lo he abandonado por cuanto no puede manejar los caracteres de cuadro y la vocales con tilde, es problematico para mi sobre todo porque yo aun programo en modo consola y utilizo mucho este tipo de caracteres.
Salu2,
GVS
luisfrancisco62
Post by luisfrancisco62 »
hola a todos:
como hago para compilar en harbour para pocket pc
gracias
mbelgrano
Post by mbelgrano »
hbide have function list and you can go to any function with right click and goto function
hbide have Syntax highlighting
rathinagiri wrote:For me, xMate editor is fantastic. The main feature is the function list. We can go to any function in no time. Syntax highlighting is also good.
