How to get the name od index of top modal window???
I'm working with huge project and I got an error:
Non top modal windos can't be released
When I display value of _HMG_SYSDATA[66] ( which contains name of windows... I think :) ) I can see empty positions:
_HMG_SYSDATA[66] : {"OknoGlowne", "OknoIndeksowanie", "_HMG_CHILDWAITWINDOW", "OknoWplaty", "OknoRejestrFaktur", "", "", ""}
What's going on?
I'm releasing all modal windows created by me...
Re: How to get the name od index of top modal window???
This shows that, the program control is in an infinite loop.
See this situation:
You call a modal window in the "on gotfocus" event of a control.
Once you are releasing the modal window just created, the previous control gets focus again. In this situation, the window focused is not the modal window. But the parent window. So you can't release a non-top modal window. Further, the focused control calls the event again and again in a loop.
Therefore, we have to avoid creating modal windows from "on gotfocus" events. Please check for this in your code.
I don't create windows on got focus. I think it's a problem within HMG. Why names of forms in _HMG_SYSDATA[66] are null strings and _HMG_SYSDATA[69] which containts type idetifiers of defined windows, too:
_HMG_SYSDATA[66] -> {"OknoGlowne", "OknoIndeksowanie", "_HMG_CHILDWAITWINDOW", "OknoWplaty", "OknoRejestrFaktur", "", "", "", "", "", ""}
_HMG_SYSDATA[69] -> {"A", "C", "C", "M", "M", "", "", "", "", "", ""}
I Think, This table should be truncated after releasing form. I think, Roberto could help us to understand this problem.
Best regards, Marek
Yes. Might be a bug. Let Roberto see this. :)
After two days of searching and studying HMG sources and my project souces, I found that my problems were caused by .Restore method...
I wrote something like that:
OknoFaktura.Restore
OknoFaktura.Release
this phrase was written about 2 years ago and till now didn't cause any crash of application.
But, now, in different circumstances this phrase causes that while releasing OknoRejestrFaktur, which was parent to OknoFaktura error about non top modal windows occurs.
Maybe something is wrong with .RESTORE method ?
I don't know, I have no time and knowledge about HMG to search it.
Maybe Roberto will give an answer to me when he will be back.
Best regards, Marek
PS. I've created a small project to test it, but, no crashes was observed :D
I'm attaching this. Maybe it will be useful for sb.
testy_modalwindow.zip
(3.54 KiB) Downloaded 244 times
