TEXTBOX to Variable
melliott42
TEXTBOX to Variable
Post by melliott42 »
Hello All,
For some strange reason I cannot set the value of a TEXTBOX to a variable. I can output the value to a MsgBox().
Works:
msgbox(oWin.txtConn_Driver.value)
Does not compile:
function test()
      local x
      x := oWin.txtConn_Driver.value
return nil
Error:
 ...Error E0030  Syntax error "syntax error at '.'"
What can you recommend?
Thanks,
Michael
Re: TEXTBOX to Variable
melliott42 wrote: ...
I recommend please send no abstracted statements but a working sample abstracted from other details ;)
Is your oWin declared in the same module as test function?
Hi Marek
Welcome back :)
You are absent for a long time :(
dhaine_adp
Post by dhaine_adp »
Hi Michael,
You've never mention if the source codes are in separate .prg source. If you are using HBClass or HMG Objects or you have created a window inside of a Class for sure that would give an error message.
Why not call test with the value of text box control?
test(oWin.txtConn_Driver.value)
function test( cTxt )
  do your processing here!
return nil
My suggestion is based on assumption only.
Danny
Danny
Manila, Philippines
esgici wrote:Hi Marek
Welcome back :)
Yes, I was on holidays (again :)).
Now, I'm slowly backing to work.
Hi Michael,
return nil
Danny
You can change your code to:
ctxt := GetProperty("oWin","txtConn_Driver","value")
test(ctxt)
melliott42
Thanks for all your suggestions. Yes the code that attempts to extract the value was in an external #INCLUDE file. I am trying to separate my GUI code from my other program logic.
I am not using CLASSES but I can see how I was misleading given that I did not post it in full (as I named my Window handle oWin). I think I'll change my naming convention there.
GetProperty("oWin","txtConn_Driver","value") did the trick! :-)
Thanks again,
Michael
dhaine_adp
Hi Marek,
test(ctxt)
Great Marek, thanks.
Danny
Danny
Manila, Philippines
I was looking for that some years ago :D
