Adaptation of FiveWin class TsBrowse to HMG
Source code related resources
Re: Adaptation of FiveWin class TsBrowse to HMG
Grigory,
Issues 1,2,3,4,6 and 7 arises in minigui ext. too, so these problems are not related with your port to HMG.
Grigory,
I've found another problem:
If you try to drag 'January' column on super columns sample, you will lost ability to move, maximize, minimize or close the window.
This problem arises on minigui ext. and the HMG port.
MigSoft
DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
Post by MigSoft »
Hay una película llamada "A mí quién me manda meterme en esto"
Tranquilo Grigory, puede ser que en la versión Tsbrowse 9.0 de Manuel Mercado
encuentres la solución. :mrgreen:
Envío todo mi apoyo para lograr el objetivo.
Saludos,
Miguel Angel Juárez A.
Google..
There is a movie called "A who's telling me to get into this"
Grigory Still, maybe in version 9.0 Tsbrowse Manuel Mercado
find the solution. :mrgreen:
Sending all my support to achieve the objective.
Miguel Angel Juarez A.
mmercado
Post by mmercado »
Dear Grigory:
I do not know a word of MiniGUI (this is my first day by here) but gladly help you in regards to TSBrowse.
Please send me an email to send you TSBrowse V.9.0 Beta.
Manuel Mercado Gómez.
manuelmercado @ prodigy. net. mx
gfilatov
Post by gfilatov »
mmercado wrote:Dear Grigory:
Hello Manuel Mercado,
Thanks a lot for your suggestion :!:
I'm glad to see you on the HMG forum very much.
My e-mail is gfilatov@freemail.ru
sudip
Post by sudip »
Hello Grigory,
I missed this topic :(
Thanks a lot :D
I just found it and downloaded your code.
For my first try I faced some problem during compilation.
May be I need to change some batch files (as I installed HMG in e:\hmg)
I shall send my feedback later. :)
After some time:
I ran it. Excellent!!! Great!!! Thanks a lot :D
I really need it.
I tested Tbrowse.1. For window 7 sample, I found some problem when double clicking any cell around middle of the window, it shows a rectangle in another place. But, this is a very small problem :)
There are some mionr rough edges also.
I haven't tested Tbrowse.2 sample yet.
Thank you again :D
After more or less one year is over, is there any improvement possible?
Hi!
I'm interested on fast tbrowse, isn't it?
What about new version?
My client is unhappy for speed of browse, in network environment, too. I've tested GRID, but I met some problems.
I'm looking for fast browsing of dbf file.
What can I use?
Best regards, Marek
Hi!
Can anybody help me, how to update this tbrowse for hmg.3.0.39?
Regards, Marek
gfilatov
Post by gfilatov »
mol wrote:Hi!
Hi Marek,
Thanks for your request!
I have an updated version this tbrowse 7.0 for hmg.3.0.39 (look for attachment).
The archive contains the all changed sources and precompiled hmg and tbrowse libraries.
You should to start build.bat with the command line 'demo.prg demo.hbc' for proper compiling the tbrowse samples.
BTW There are a known bugs reported on this forum in this updated version :x
This distribution is provided AS IS, without any warranty.
TBrowse Demo 2 screenshot
hmg-tbrowse-7.zip
TBrowse update
(598.74 KiB) Downloaded 559 times
