Adaptation of FiveWin class TsBrowse to HMG
Re: Adaptation of FiveWin class TsBrowse to HMG
If the in-place edit cell is a spinner, we can't get out using key board. We have to click another cell with mouse to get away.
Also, the previous data in in-place edit text box is not deleted once we start typing new data. Is that configurable?
Thanks for your bugreport!rathinagiri wrote:If the in-place edit cell is a spinner, we can't get out using key board. We have to click another cell with mouse to get away.
It seems that a similar wrong behaviour exists in minigui ext.'s adaptation also
It's must be fixed (the reason is different behaviour between TextBox and GetBox controls).rathinagiri wrote:Also, the previous data in in-place edit text box is not deleted once we start typing new data. Is that configurable?
There is an idea to select the value on gotfocus text box
Yep. You are right!
- Roberto Lopez
- HMG Founder
Despite I've asked you to port GETBOX references in TSBROWSE to TEXTBOX, if you consider necessary to add GETBOX code to TSBROWSE to achieve adequate functionality, please, do it. No problem from my part.gfilatov wrote:It's must be fixed (the reason is different behaviour between TextBox and GetBox controls).rathinagiri wrote:Also, the previous data in in-place edit text box is not deleted once we start typing new data. Is that configurable?
If you do it, please, include GETBOX code under the same conditional compilation constant as TSBROWSE.
TIA.
ALELUYA....
MUCHAS MUCHAS MUCHAS GRACIAS
very very very thanks
...::: SPANISH:
Gracias Grigory!!!
Excelente!
En el ejemplo 1 (c:\hmg\SAMPLES\tbrowse.1) si seleciono el menú "Samples on Window" y escojo el "Sample 7", al editar la columna "STATE", arroja varios errores.
Un abrazo.
...::: ENGLISH:
Grigory Thanks!
Excellent!
In example 1 (c: \ hmg \ SAMPLES \ tbrowse.1) if selects the menu "Samples on Window" and choose the "Sample 7" in editing the column "STATE", gives several errors.
A hug.
Gracias Grigory!!!
Excelente!
Un abrazo.
...::: ENGLISH:
Grigory Thanks!
Excellent!
A hug.
Saludos, Fernando Chirico.
- Roberto Lopez
- HMG Founder
Grigory,
I've briefly tested and I've found some little problems:
1. When changing column width using mouse, vertical bars stays in the bottom of TBROWSE window (it arises in various samples). 2. In sample 7 (browse on window) when clicking cells a cell frame is drawn at a position different from the clicked cell one (upper left): 3. Moving mouse pointer over headers, cursor flicks.
4. Dragging vertical scrollbar does not work (in all samples).
5. Combo does not match cell height in sample 2 (window): 6. In super columns sample, when you attempt to drag the 'January' column, the four arrows pointer is shown, but the column can´t be dragged.
7. In super headers (bitmaps) sample, if you go to the last column and click the horizontal scrollbar (the space between bar left arrow and bar button) you will not be able to scroll to the left. 8. Report / Excel connectivity present (apparently) a problem with the paper size and/or orientation: 9. I've got randomly (or via an undiscovered steps sequence) the following error:
10. I've got some errors on editing:
I hope this info be useful.
Error BASE/1004 No exported method: EVALI've tested with HMG 3.0.34 on Windows 7.@...TEXTBOX: Wrong InputMask Definition
Other error on the demos to edit the cell "NAME":
- error.JPG (71.31 KiB) Viewed 8180 times
