Why the MAIN Window always behind the CHILD Windows?
Re: Why the MAIN Window always behind the CHILD Windows?
IMHO it is not only the property of HMG but also the property of Win32, or even GTK. Please try GIMP. Or open MS-Excel. Press Ctrl+F (search window). The search window is a child window, which will always be in front of the main window! So, the main window will be behind a child window.
In GUI applications, main window is a background window and all operations are handled through either child windows or modal windows. If you want to handle both main and child windows at a time, it has to be designed such that, there will be space for both the windows. (Like HMG-IDE)
Hi,bootwan wrote:There is no one reply. I show the pictures to explain it.
The following application has a MAIN window "Program Main Menu" with TREE control in it for user to choosing program item.
If we open CHILD forms (Customers, Suppliers and Employees), we can see the whole form by click the title of form.
But it will not show the whole form when we click the MAIN window "Program Main Menu"
Try to use WINDOWTYPE STANDARD instead of WINDOWTYPE CHILD for child windows
Hope that helps
Thanks for the info Grigory.
You can't call C functions like this. We have to pass the necessary variables to the C functions via 'HB_FUNC'.
Consider your code:
And, hb_bitor, hb_bitand,hb_bitnot can not be used inside C Code. We have to find some equivalent functions in C.
Consider your code:
STATIC FUNCTION ShowInTaskBar(cFormName, lVisible)
LOCAL hWnd, nStyle
hWnd := GetFormHandle(cFormName)
if lVisible
HBSetWindowLong(hWnd,1)
HBSetWindowLong(hWnd,0)
#pragma BEGINDUMP
#include <windows.h>
#include <commctrl.h>
#include "hbapi.h"
#include <wingdi.h>
HB_FUNC ( HBSETWINDOWLONG )
HWND hWnd1;
hWnd1 = (HWND) hb_parnl (1);
if (hb_parni(2) = 1)
SetWindowLong( hWnd1, GWL_EXSTYLE, HB_BITOR( GetWindowLong(hWnd1, GWL_EXSTYLE), WS_EX_APPWINDOW ) );
SetWindowLong( hWnd1, GWL_EXSTYLE, HB_BITAND( GetWindowLong(hWnd1, GWL_EXSTYLE), HB_BITNOT(WS_EX_APPWINDOW) ) ) ;
#pragma ENDDUMP
- Roberto Lopez
- HMG Founder
Child windows does not appear on taskbarbootwan wrote:Great! Great!
It appears as what I wanted.
Thanks to gfilatov.
Another question is how to hide the standard forms from TaskBar?
Cause HMG has no the property "ShowInTaskbar".
