How to link icons to program?
Maybe my question is trivial, but I can't find how to link some icons to program?
Could somebody help me?
Re: How to link icons to program?
Marek,mol wrote:Maybe my question is trivial, but I can't find how to link some icons to program?
How about to including in your <programname>.rc the following string(s):
// Using a resource file like this, you can include bitmaps, icons and sounds
// inside EXE.
// Resource name Resource Type Resource FileName
WORLD ICON WORLD.ICO
Going this way, I preperad .rc file, but in my opinion, it doesn't work.
If I declare icon in window definition, it appears.
But main program listed in folder has standard icon from ide.
My older project, linked with hmg 2.0 and older IDE has icon.
Maybe something with IDE ???
Had you mentioned all your resources in the IDE resources page of the Project Browser window? (instead of listing them in a .rc file)
It works fine for me.
I have all resources placed in "Resrc." tab:
but still only standard icon appears in my AKORD.EXE
icon and ICON are the same? And, is there any empty space after the last line?
I don't understand why this happens.
thanks! it must be "ICON" not "icon" !!!
So simply then so hard to find error...
Best regards, Marek
Best regards, Marek
Ok Hello to all on this forum
i'm new in programming hmg ide : excellent !
i have a problem with icons and bitmaps . I want to include the .bmp of my program in the executable:
I have include in the ressource of program the list of them like
SAVE BITMAP FREE.BMP etc..
But these bitmaps don't link in the exe
(i have try with an rc file but the same pb)
However when i use the resource witn :
WORLD ICO SOMETHING.ICO : no problem
thank's in advance
regards, jean-michel kimono59
DEFINE MAIN MENU
DEFINE POPUP "File"
MENUITEM "Open" ACTION MsgInfo("Open") IMAGE "info.bmp"
MENUITEM "Save" ACTION MsgInfo("Save") IMAGE "free.bmp"
SEPARATOR
MENUITEM "Exit" ACTION ThisWIndow.Release IMAGE "exit.bmp"
END POPUP
DEFINE POPUP "Help"
MENUITEM "About" ACTION MsgInfo("HMG IDE - Menu Designer")
END POPUP
END MENU
thank's in advance
Bon a priori on ne veut pas me répondre, dommage, merci quand même !
