Problem with prototype KPI - Dashboard Created in HMG
- dhaine_adp
Hello Friends,
I have attached a test file for which I am having a problem with flickering display of graph that seems to be a side effect of scrolling label (a.k.a. marquee). This prototype is suppose to be displayed on a 46 inches Sony HD/LCD attached to a workstation.
The program runs on tray icon when minimized. It will be run by another program via execute command.
I am quite aware that HMG is not optimized for graphic display but is there a work around with the flickering?
The KPI-Dashboard can be easily produced in MS Excel but the display would look dull and dry if there are no moving text. For that reason I added a label that moves with HMG, of course. I was planning to put another label which scrolls a bit faster than the other one but because I can't eliminate the flickering of the graph, the other label is not added.
I would appreciate it very much if you can suggest a way to eliminate the flickering of graph.
Another problem that I encountered is when the window is initially displayed, the graph does not appear. However when you click maximize and then restore or minimize, the graph is shown? Why? I don't know either....
The attached program is compiled with HMG 3.0.33.
TIA and regards,
Danny
TIA and regards,
Danny
- TestKPI-Dashboard.zip
- Test KPI-Dashboard
- (3.15 KiB) Downloaded 380 times
Danny
Manila, Philippines
Danny
Manila, Philippines
- esgici
Re: Problem with prototype KPI - Dashboard Created in HMG
Hi Danny
undefined reference to `HB_FUN_MULTIMESSAGE'
( A new competitor to MsgMulti() ? )
Viva INTERNATIONAL HMG
- dhaine_adp
No it's not a competitor, I just renamed it.Hi Danny
Anyway I repost the source code without that call and replace it with msginfo().
#include "minigui.ch"
#define PRODUCTID "KPI"
#define PRODUCTNM "Dashboard"
#define CLIENT ""
#define VERSIONID 1.0
#define HOMEPAGE ""
#define SERVERADD ""
#DEFINE FILLER SPACE(3)
#define FALSE .F.
#define TRUE .T.
REQUEST DBFCDX, DBFFPT
function Main()
Local aSer:={ {14280,20420,12870,25347, 7640},;
{ 8350,10315,15870, 5347,12340},;
{12345, -8945,10560,15600,17610} }
*--> control flag to monitor windows minimize and restore events
PRIVATE lWndMin := FALSE
*--> control flag to monitor windows maximize and restore events
PRIVATE lWndSize := FALSE
ANNOUNCE RDDSYS
SET FIXED ON
SET DECIMALS TO 2
SET MULTIPLE OFF WARNING
SET DATE AMERICAN
SET CENTURY ON
SET EPOCH TO 1950
SET WRAP ON
SET SCOREBOARD OFF
SET DELETED ON
SET CONFIRM ON
SET BELL ON
SET FONT TO "Verdana" , 9
SET NAVIGATION EXTENDED
SET BROWSESYNC ON
SET TOOLTIPSTYLE BALLOON
SET TOOLTIPBACKCOLOR { 255 , 255 , 255 }
SET TOOLTIPFORECOLOR { 0 , 0 , 0 }
RDDSETDEFAULT("DBFCDX")
DEFINE WINDOW MainForm ;
WIDTH 640 HEIGHT 480 ;
TITLE PRODUCTNM + " Version " + ALLTRIM( STR( VERSIONID ) ) ;
MAIN ;
ICON "graph.ico" ;
NOTIFYICON "graph.ico" ;
NOTIFYTOOLTIP PRODUCTNM ;
ON INIT ( ShowDashboard(), DrawBarGraph( aser ) ) ;
ON MINIMIZE ShowDashboard() ;
ON MAXIMIZE Resize( TRUE ) ;
ON SIZE Resize( FALSE ) ;
ON NOTIFYCLICK ShowDashboard() ;
ON INTERACTIVECLOSE ForceClose()
DEFINE NOTIFY MENU
ITEM "About..." ACTION MSGINFO("Dashboard", "About")
SEPARATOR
ITEM 'Exit Dashboard' ACTION MainForm.Release
END MENU
@ GetDesktopHeight() - 110, 0 LABEL Dummy OF MainForm VALUE "" HEIGHT 40 WIDTH GetDesktopWidth();
FONT "ARIAL" SIZE 10 BACKCOLOR RED FONTCOLOR YELLOW
@ GetDesktopHeight() - 100, 0 LABEL lblCritical OF MainForm VALUE "Critical" HEIGHT 20 WIDTH GetDesktopWidth();
MainForm.Center()
MainForm.Activate()
RELEASE ALL
Procedure DrawBarGraph ( aSer )
ERASE WINDOW MainForm
DRAW GRAPH ;
IN WINDOW MainForm ;
AT 20,20 ;
TO 400,610 ;
TITLE "Sales and Product" ;
TYPE BARS ;
SERIES aSer ;
YVALUES {"Mon","Tue","Wed","Thu","Friday"} ;
DEPTH 15 ;
BARWIDTH 15 ;
HVALUES 5 ;
SERIENAMES {"PRODUCT A","SHAMPOO B","PRODUCT K"} ;
COLORS { {128,128,255}, {255,102, 10}, {55,201, 48} } ;
3DVIEW ;
SHOWGRID ;
SHOWXVALUES ;
SHOWYVALUES ;
SHOWLEGENDS ;
NOBORDER
static function ForceClose()
LOCAL lRetVal := FALSE
lRetVal := MSGYESNO( "Exit Dashboard?", "Please confirm" )
IF lRetVal
MainForm.Release()
DestroyWindow()
RETURN lRetval
static function DestroyWindow()
DBCLOSEALL()
RELEASE WINDOW ALL
static function Resize( lMaxMinSize )
LOCAL nDeskTopWidth := GETDESKTOPWIDTH()
LOCAL nDeskTopHeight := GETDESKTOPHEIGHT()
IF lMaxMinSize
**--> Windows Maximize event
**--> Windows Minimize event
static function ShowDashboard()
STATIC nRunOnce := 0
IF lWndMin
lWndMin := FALSE
MainForm.Restore()
ScrollLabel(FALSE)
lWndMin := TRUE
MainForm.Hide()
ScrollLabel(TRUE)
static function ScrollLabel(lExit)
LOCAL nRow := GetDesktopHeight() - 100
LOCAL nCol := GetDesktopWidth()
LOCAL ii := nCol
LOCAL cText := "PRODUCT A (10/200) -- SHAMPOO B (3/100) -- PRODUCT K (13/20)"
LOCAL cShowThis := ""
LOCAL nCharCount := 0
LOCAL nCharPos := 1
LOCAL nWidth := 0
nCharCount := len( cText )
WHILE TRUE
if lExit
EXIT
if ii < 0
if len( MainForm.lblCritical.Value ) = 1
MainForm.lblCritical.Value := ""
MainForm.lblCritical.Width := 0
nCharPos := 1
cShowThis := ""
ii := nCol
MainForm.lblCritical.Hide
cShowThis := alltrim( substr( MainForm.lblCritical.Value, 2 ) )
nWidth := GetTextWidth( nil, cShowThis, "Arial" )
MainForm.lblCritical.Width := nWidth
MainForm.lblCritical.Value := cShowThis
MainForm.lblCritical.Show
Delay( 700000 )
cShowThis += substr( cText, ( nCharPos++ ), 1 )
** MainForm.lblCritical.Hide
MainForm.lblCritical.Col := ii
** MainForm.lblCritical.Show
ii--
Delay()
do events
END
static function Delay(nDelay)
LOCAL nIterate := 0
IF VALTYPE( nDelay ) == "U"; nDelay := 190000; endif
WHILE nIterate++ < nDelay; END; nIterate := 0
RETURN nil
-Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
- dhaine_adp
Hi Friends,
Another thing concerning with this problem, the red band at the bottom displays the current inventory level as it happened. And all those text that would appear supposed to be is the inventory items which is below SKU (safe keeping unit). So I might say that the production planner/scheduler and or purchaser could make a more informed decision for adjustment or whatever he should supposed to do.
If you apply the same principles to a hospital, visually you can find your inventory items, available rooms, A/R, F/S by selecting a proper dashboard display on notify menu.
That's my humble idea regarding that Dashboard prototype. Posibilities of application is numerous (or endless if we can call it that way).
I think even for meteorological data in tandem with Campbell Weather instrument, a good Dashboard can be made.
Well I am hoping that I can found solution to it because I really like to accomplish it by HMG code.
Danny
Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
- esgici
It was only a jokedhaine_adp wrote: ...
I can't found any problem in your program.
IMHO source of problem is from DRAW GRAPH. When replaced it with another control (fe an image) flickering go away. Happen same thing when extracting Restore / Hide MainForm lines (or changing Restore to Show )from ShowDashboard(). But in this second case label doesn't scroll.
Also, I can't any explanation for second (why graph doesn't appears at init?) problem.
Anyway your program is very nice and your method for scrolling label is impressive.
Please notify us when you will found the solution.
To see the graph while init, add this as line number 63 too.
on gotfocus DrawBarGraph( aser );
Giving a draw command before window paint procedure starts won't actually draw them because how can you draw a picture where there is no wall?. Once the window is activated or painted or shown in the screen, if you give draw command, that will be painted immediately.
When you call on gotfocus, the window is already painted. So, when we call draw command, the graph is drawn.
Regarding the flickering effect, if we can draw the graph in a separate window that will not be repainted when the text is scrolled.
Kindly try this code...
- esgici
Hi Rathi
Nothing changed
Nothing changed
Very sorry.
I had uploaded the same file.
Now please try this.
