Hello Linux!!!
Hello Linux!!!
For those finding interesting the experimentation, here are some tips:
1. Install Ubuntu 10.04.
2. Download and install Harbour compiler for Ubuntu: http://sourceforge.net/projects/harbour ... b/download
3. Install Development files for the GTK+ library. You can do it with Synaptic Package Manager (libgtk2.0-dev).
4. Create a file called test.prg (with the code below) and build it with hbmk test `pkg-config --cflags --libs gtk+-2.0` command . Run it with ./test
test.prg:
function main()
	PUBLIC bButtonAction := { || GTK_MSGINFO('Click!!!') }
	GTK_INIT()
	aRet := GTK_DEFINEWINDOW( 100 , 100 , 400 , 200 , "hello Linux!!!!" )
	GTK_DEFINEBUTTON ( aRet [2] , 50 , 50 , 'Click Me!!' )
	GTK_ACTIVATEWINDOW()
return nil
PROCEDURE HMG_BUTTON_CALLBACK ( HANDLE )
	EVAL ( bButtonAction )
#pragma BEGINDUMP
#include <gtk/gtk.h>
// BUTTON ONCLICK EVENT HANDLER ////////////////////////////////////
static long button_clicked ( GtkWidget *handle )
	static PHB_DYNS Dyns = 0 ;
	long int r;
	if( ! Dyns )
		Dyns = hb_dynsymFindName( "HMG_BUTTON_CALLBACK" );
	hb_vmPushSymbol( hb_dynsymSymbol( Dyns ) );
	hb_vmPushNil();
	hb_vmPushLong( (long) handle );
	hb_vmPushLong( 0 );
	hb_vmPushLong( 0 );
	hb_vmPushLong( 0 );
	hb_vmDo( 4 );
	r = hb_parnl( -1 );
	return r;
static gboolean delete_event( GtkWidget *widget,GdkEvent  *event, gpointer   data )
    g_print ("delete event occurred\n");
    return FALSE;
static void destroy( GtkWidget *widget, gpointer   data )
    gtk_main_quit ();
HB_FUNC ( GTK_INIT )
    gtk_init ( 0 , 0 );
HB_FUNC ( GTK_DEFINEWINDOW )
	GtkWidget *window;
	GtkWidget *fixed;
	char* cTitle = (gchar*) hb_parc(5);
	window = gtk_window_new (GTK_WINDOW_TOPLEVEL);
	g_signal_connect (window, "delete-event",G_CALLBACK (delete_event), NULL);
	g_signal_connect (window, "destroy",G_CALLBACK (destroy), NULL);
	gtk_window_move( GTK_WINDOW(window) , hb_parni(2), hb_parni(1) );
	gtk_widget_set_size_request( GTK_WIDGET(window) , hb_parni(3) , hb_parni(4) );
	gtk_window_set_title( GTK_WINDOW(window) , cTitle );
	/* Create a Fixed Container */
	fixed = gtk_fixed_new ();
	gtk_container_add (GTK_CONTAINER (window), fixed);
	gtk_widget_show (fixed);
	gtk_widget_show  (window);
	hb_reta(2);
	hb_storvnl( window , -1 , 1 );
	hb_storvnl( fixed , -1 , 2 );
HB_FUNC ( GTK_DEFINEBUTTON )
	GtkWidget *button;
	button = gtk_button_new_with_label ( (gchar*) hb_parc(4));
	gtk_fixed_put (GTK_FIXED ((long) hb_parnl(1)), button, hb_parni(2), hb_parni(3) );
	gtk_widget_show (button);
g_signal_connect (G_OBJECT (button), "clicked", G_CALLBACK (button_clicked), (gpointer) button );
HB_FUNC ( GTK_ACTIVATEWINDOW )
	gtk_main ();
HB_FUNC ( GTK_MSGINFO )
GtkWidget *dialog;
	dialog = gtk_message_dialog_new ( 0 ,
                                  GTK_DIALOG_MODAL,
                                  GTK_MESSAGE_INFO,
                                  GTK_BUTTONS_OK,
                                  (gchar*) hb_parc (1) ,"Hi1" );
	gtk_dialog_run (GTK_DIALOG (dialog));
	gtk_widget_destroy (dialog);
#pragma ENDDUMP
Enjoy!
Re: Hello Linux!!!
Aha! Super!
Re: Hello Linux!!!
rathinagiri wrote:Aha! Super!
GTK is amazing.
As I've already pointed sometimes, it is the foundation used by GNOME (the Ubuntu default desktop).
GTK is compact, simple and fast. It is extremely easy compared with Windows API.
So, for those wanting GUI support on Linux, it appeared a good idea to show how much easily, the things can be done.
jparada
Re: Hello Linux!!!
Post by jparada »
This is my first test and this is the result, please take a look.
javier@javier:~/testhmg$ hbmk test `pkg-config --cflags --libs gtk+-2.0`
Harbour 2.1.0beta1 (Rev. 14450)
Copyright (c) 1999-2010, http://www.harbour-project.org/
Compiling 'test.prg' and generating preprocessed output to 'thread'...
Lines 111, Functions/Procedures 2
Generating C source output to 'test.c'... Done.
test.prg: In function ‘button_clicked’:
test.prg:30: warning: assignment makes pointer from integer without a cast
test.prg: In function ‘HB_FUN_GTK_MSGINFO’:
test.prg:109: error: expected declaration or statement at end of input
Any help is welcome.
Thanks
PS: Under VM Ubuntu 10.4
Best Regards
Javier
Re: Hello Linux!!!
jparada wrote:Hi,
Thanks
Best Regards
Javier
At copypasting I've missed a right bracket before #pragma ENDDUMP.
Please add it and it should work.
sudip
Re: Hello Linux!!!
Post by sudip »
Great News! Roberto, thank you very much :)
Regards.
jparada
Re: Hello Linux!!!
Post by jparada »
Thanks a lot Roberto, now works fine
I attached picture, please take a look
Thanks
Best Regards
Javier
Re: Hello Linux!!!
jparada wrote:Hi,
Thanks
Best Regards
Javier
Congratulations!
l3whmg
Re: Hello Linux!!!
Post by l3whmg »
Hi Roberto,
you are SIMPLY THE ...GREAT!!
And now I must find a PC to install Linux, learn this SysOp, etc., etc., etc. :lol:
I always say to you: MANY THANKS!
Best Regards
Luigi from Italy
www.L3W.it
Re: Hello Linux!!!
Since this is cross platform, this can be compiled in Windows too. Isn't it?!
What are the tools to be installed in windows?
