Gridlines for ListBox
Can we have Gridlines for ListBox as in Grid?
- Roberto Lopez
- HMG Founder
Re: Gridlines for ListBox
Nop!rathinagiri wrote:Can we have Gridlines for ListBox as in Grid?
AFAIR, Windows API don't have such feature.
You could use a grid with no headers and only one column.
That will give you the same result.
Thanks for the answer and instant solution Roberto.
- esgici
Header-less GRID ? Not "empty header", isn't ?Roberto Lopez wrote: ...
You could use a grid with no headers ...
Please give a little example; I need eagerly it !
Best regards
Viva INTERNATIONAL HMG
Hi Esgici,
Please take a look at this:
Please modify grid.02 example and apply the change:
instead of
Best Regards
Javier
NOHEADERS ;Code: Select all
HEADERS {'Column 1','Column 2','Column 3'} ;Javier
- esgici
Gracias Javier
I had missed it in the documentation
