how to explore many tables
l3whmg
Post by l3whmg »
Hi friends,
I need your help to understand which is the best way or approach to explore concurrently some tables.
I have this pattern tables (limited to fields that are correlated with each other):
Tab1.FieldN = Id_Code => Primary Key
Tab2.FieldX = Id_Code => Indexed but not Primary Key
Tab3.FieldY = Id_Code => Indexed but not Primary Key
Where Id_Code is the same value: typical example of a relationship of one to many!
one Tab1.Record to many Tab2.Records
one Tab1.Record to many Tab3.Records
With the Xbase language, I think I can use two alternative:
A) DBSETRELATION or B) FILTER
My problem is: how can I scan from the beginning to the end of Tab1 and concurrently scan all related records on both Tab2 and Tab3?
Many thanks in advanced
Luigi from Italy
www.L3W.it
dhaine_adp
Re: how to explore many tables
Post by dhaine_adp »
Hi Luigi,
In traversing the tables, you should use do while loop and check your primary key against the key of the second table and on the third table and so on. That is a loop within a loop.
But make sure that you would not end up in endless loop. Example:
function main()
local PrimaryKey, DetailKey, RemKey
use invoicehead alias INVHEAD new
index on InvoiceNbr to Invoice
use invoicedetails alias INVDETL new
index on InvoiceNbr
use remarks alias REMARKS new
index on InvoiceNbr+LineNbr
dbselect("INVHEAD")
dbgotop()
do while !eof()
   PrimaryKey := INVHEAD->InvoiceNbr
   do while !eof() .and. INVDETL->InvoiceNbr == PrimaryKey
       DetailKey := PrimaryKey + LineNbr
       do while !eof() .and. ( ( REMARKS->InvoiceNbr + REMARKS->LineNbr ) == DetailKey )
           dbskip()
       enddo
       dbskip()
    enddo
    dbskip()
enddo
dbcloseall()
return
I hope that helps...
Danny
Danny
Manila, Philippines
Hi Danny,
Shouldn't select relevant table before giving dbskip()?
dhaine_adp
Thanks for pointing out the mistake I made... :oops: :P
Luigi,
Sorry, here is the corrected sample:
function main()
index on InvoiceNbr
dbselect("INVHEAD")
dbgotop()
do while !eof()
   dbselectarea( "INVDETL")
   dbseek( PrimaryKey )
       dbselectarea( "REMARKS" )
       dbseek( DetailKey )
           dbskip()
       enddo
       dbselectarea( "INVDETL" )
       dbskip()
    enddo
    dbselectarea( "INVHEAD" )
    dbskip()
enddo
dbcloseall()
return
Danny
Manila, Philippines
l3whmg
Post by l3whmg »
Hi friends,
many thanks for your quickly answer.
Thanks Dany, but what you have proposed is also what I normally use. I thought there was a different solution, another pov. Anyway thank you very much for your interest. :)
To avoid problems reported by Rathi, I always use the table name before the instructions as "DBGOTOP, DBSKIP" without using "DBSELECTAREA" that I use only in specific situation ;).
This question is borned because I'm try to develope a simple contact manager, that I want publish and submit to HMG forum, and I want to make it "fairly" well ;) and I have some tables with the same referrer.
Best Regards
Luigi from Italy
www.L3W.it
Contact Manager?!
Very good Luigi. Waiting for your utility...
Czarny_Pijar
Post by Czarny_Pijar »
Unfortunately, the code provided by dhaine_adp does'nt fulfill the requirements of l3whmg:
l3whmg wrote: typical example of a relationship of one to many!
Look at the attachment for the correct solution, even in 2 flavours:
1st - straight from the school board, and
2nd - optimezed for speed ( both checked, works well).
Sorry for the delay, the problems with the IDE and the grids has been just resolved :oops:
master_deatail_scan.zip
(3.23 KiB) Downloaded 512 times
l3whmg
Post by l3whmg »
Hy Czarny_Pijar,
many thanks for your answer: I'll look at your example!
Best Regards
Luigi from Italy
www.L3W.it
nguyenchiduc
Post by nguyenchiduc »
I have to work with multiple tables at once, each table is a different index. Each table has hundreds of thousands or millions of records
Results return to the temporary tables. For example data_view1, data_view2 ... data_view_n
If the search index is used to return results very quickly even though many records, search on multiple tables to retrieve relevant information
Definition of GRID for data_view1, data_view2 ... data_view_n to see the results on screen.
@ x1, y1 GRID Grid_data_view1 ... ROWSOURCE 'data_view1'
@ X2, y2 GRID Grid_data_view2 ... ROWSOURCE 'data_view2'
@ xn, yn GRID Grid_data_view_n ... ROWSOURCE 'data_view_n'
For example, I have the table:
Table1: index1
Table2: index1, index2 ...
Table3: index2, index3 ...
Table_N: index_(n-1), index_n ...
select data_view1
zap
select data_view2
zap
select data_view_n
zap
select Table1
seek object_search_1
IF FOUND() ==  .T.
      select Table2
      seek Table1->object_search_1
      IF FOUND() ==  .T.
           select Table3
           seek Table2->object_search_2
           IF FOUND() ==  .T.
                select Table4
                seek Table3->object_search_3
                IF FOUND() ==  .T.
                     DO WHILE Table3->object_search_3 == something
                           select data_view
                           append blank
                            data_view-Field1 := Table3->Field1
                            data_view-Field2 := Table3->Field2
                            data_view->FieldN := Table3->FieldN
                            data_view->( DBCOMIT() )
                            skip
                     ENDDO
                    /* Else Commands  */
                /* Else Commands  */
           /* Else Commands  */
    /* Else Commands  */
nguyenchiduc
Below is a main table of data (bottom), looking from 4 different tables. Each table has hundreds of thousands to millions of records
The displayed information is always changing depending on the change of the main table.
