Help whit grid
martingz
Help whit grid
Post by martingz »
I use a grid control for display some information
control is fed with data from a table and can be variable
between every operation I empty the grid
but on some occasions is fine and sometimes not
remain 1 o 2 lines
i use next code to empty
mconst:=conspag.Grid_1.ItemCount
for t=1 to mconst
conspag.Grid_1.DeleteItem(t)
next
sorry for my bad english
Re: Help whit grid
First of all we have a special method to delete all items, so, you can use,
conspag.Grid_1.deleteallitems()
In the case of your example, once you delete the first item, second item becomes the first item! So, that will be a problem.
The correct logic would be
for t= mconst to 1 step -1
next
martingz
Re: Help whit grid
Post by martingz »
Tanks rathingari
i don't find about deleteallitems() info
i check my documentation probably is bad o old
thanks again for your help
