Hello,
how can I set Record Number in database grid, while this function is not allowed for filtered/conditional indexed tables.
HMG 3.0.31
Grid.RecNo:=recno()
Best regards Rado
GRID Set RecNo in filtered/conditional tables
radohabjan
- dhaine_adp
Re: GRID Set RecNo in filtered/conditional tables
Hi Rado,
Have you tried Grid.RecNo := ordkeycount(), assuming that the current work area is your database.
Danny
Danny
Danny
Manila, Philippines
Danny
Manila, Philippines
- Roberto Lopez
- HMG Founder
I've done so, since, you could try to set recno to a non-visible record (because filter or conditional index) creating a malfunction.
I plan to add some kind of check to find if a record is visible or not and allow or ignore the operation.
radohabjan
Hello Roberto,
problem is only when SET DELETED is ON, with OFF works fine.
br Rado
br Rado
