Hi friends,
I've tried to read about this new window type and it's use, but...
First of all I don't understand if I can use this new window type inside CHILD form.
After this, I've tried to use it but I receive an error during execution of my code.
I've included a sample prg and an error screenshot. I've defined/used form (with panel) one time as CHILD and one time as MODAL, but the error it's the same.
Many thanks in advantage
PANEL - new window type
- PanelTest.zip
- (34.29 KiB) Downloaded 389 times
Luigi from Italy
www.L3W.it
www.L3W.it
Re: PANEL - new window type
Hi,l3whmg wrote:Hi friends,
Please try the following working sample with CHILD form usage:
FUNCTION main()
p000_Define()
p001_Define()
ACTIVATE WINDOW p001win, p000win
* Main form definition
STATIC FUNCTION p000_Define()
DEFINE WINDOW p000win ;
WIDTH 860 ;
HEIGHT 645 ;
TITLE 'Panel tester' ;
WINDOWTYPE MAIN ;
FONTNAME "Arial" FONTSIZE 12
DEFINE MAIN MENU
DEFINE POPUP '&File'
MENUITEM 'e&Xit' ACTION p000win.Release
END POPUP
DEFINE POPUP '&Open Form'
MENUITEM '&Do' ACTION p000_OpenForm()
END POPUP
END MENU
p000win.Center
* Sub (and panel) form definition
STATIC FUNCTION p001_Define()
DEFINE WINDOW p001win ;
WIDTH 700 ;
HEIGHT 525 ;
TITLE 'Sub Form' ;
WINDOWTYPE CHILD ;
NOAUTORELEASE ;
ONINIT p001win.Hide ;
DEFINE TOOLBAR toolbar1 ;
BUTTONSIZE 60,30 ;
FONT "Arial" ;
SIZE 10 ;
FLAT ;
BORDER
BUTTON bt_exit ;
CAPTION 'e&Xit' ;
ACTION p001win.Hide ;
SEPARATOR
END TOOLBAR
DEFINE WINDOW Win_2 ;
ROW 80 ;
COL 30 ;
WIDTH 300 ;
HEIGHT 200 ;
VIRTUALWIDTH 400 ;
VIRTUALHEIGHT 400 ;
WINDOWTYPE PANEL
DEFINE LABEL lb_label1
ROW 10
COL 10
VALUE 'Panel window...'
WIDTH 300
END LABEL
p001win.Center
* Sub (and panel) form open
STATIC FUNCTION p000_OpenForm()
p001win.Show
p001win.Setfocus
RETURN NILKind Regards,
Hi Grigory,
many thanks! Work fine...with little trick
Best regards
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
- Roberto Lopez
- HMG Founder
Using ACTIVATE WINDOW ALL command, NOAUTORELEASE style is assumed for all windows (excepting main).l3whmg wrote:Hi friends,
Panel windows can't have the autorelease style, because their 'embedded' nature.
I'll reinforce error checking to warn the user about this.
Thanks for reporting.
- Roberto Lopez
- HMG Founder
I've already fixed. Avoiding that Panel windows be double activated by ACTIVATE WINDOW ALL command.Roberto Lopez wrote:Using ACTIVATE WINDOW ALL command, NOAUTORELEASE style is assumed for all windows (excepting main).l3whmg wrote:Hi friends,
I've found a problem with 'restore' method used by you (instead of 'show'). It not worked for non-visible windows.
Thanks again for reporting.
Hi Roberto,
many, many thanks to you forf your great job HMG!
Best regards
Best regards
Luigi from Italy
www.L3W.it
www.L3W.it
