QUIT problem
fprijatelj
Re: QUIT problem
Hi
This is possible solution:
Put this directive in myCommands.ch
#xtranslate QUIT => CLOSE ALL ; RELEASE WINDOW ALL
then include myCommand.ch in your prg files:
#include myCommand.ch
And you can safely use QUIT command.
Maybe this directive should be put in one of the system ch files (i_misc.ch) ?
BRGDS
Franček
BRGDS
Franček
- srvet_claudio
Re: QUIT problem
Thanks Esgici
but in programming I am still a baby calf
Fprijatelj, very professional your code
greetings to all
Claudio
greetings to all
Claudio
- esgici
Re: QUIT problem
Nice solution, Franček
May be our Maestro will put it official headers file of HMG.
Claudio,
IMO, regarding your previous work, ( puzzle game ), you are a very robust bull in programing
(low level approach to high level needs; such as multi language feature changeable at run time etc)
Saludos and Regards
Claudio,
Saludos and Regards
Viva INTERNATIONAL HMG
- srvet_claudio
Re: QUIT problem
Esgici,
thanks for your words.
Best regards
Claudio
Best regards
Claudio
- Roberto Lopez
- HMG Founder
Re: QUIT problem
I'll add to hmg.ch.fprijatelj wrote:Hi
BRGDS
Franček
Thanks.
- Roberto Lopez
- HMG Founder
Re: QUIT problem
I've already fixed. The fix will be available in 3.0.26.fprijatelj wrote:Hi
BRGDS
Franček
It is based on your suggestion.
I've only omitted the CLOSE ALL command, since RELEASE WINDOW ALL command invokes the ReleaseAllWindows() function that includes a call to dbcloseall().
Re: QUIT problem
Hi, Roberto
Something is happend with command QUIT i think is overlaped the commad oExcel:Quit(), attached please find a little example. the error that these show is: Test.prg(52) Error E0030 Syntax error "syntax error at 'WINDOW'"
Ed
Hola Roberto,
Algo esta pasando con el comando QUIT , creo que esta traslapando el comando oExcel:Quit(), adjunto un pequeño ejemplo, el error que muestras es:
Saludos,
Ed
Ed
Hola Roberto,
Saludos,
Ed
- oExcel1.zip
- (2.01 KiB) Downloaded 282 times
- esgici
Re: QUIT problem
Hi Ed
Are you sure Quit() is a valid OLE (Excel Class) method ?
Does may be Close() ?
Regards, saludos
Regards, saludos
- Roberto Lopez
- HMG Founder
Re: QUIT problem
I'll check it ASAP.Steed wrote:Hi, Roberto
Ed
Hola Roberto,
Saludos,
Ed
Thanks for reporting.
Re: QUIT problem
Hi, Esqici
Off course, the command is oExcel:Quit
BTW, Roberto i put a small update in the sample, in the same link of the first post.
Eduar
Eduar
