Grid rename via IDE
Czarny_Pijar
Grid rename via IDE
Post by Czarny_Pijar »
My efforts to re-create rathinagiri's sudoku in the IDE enviroment has been stopped suddenly when I tried to rename from 'Grid_1' to 'sudoku' in the 'Object Inspector' window.
HMG Errorlog File
Date:2010.04.25 Time: 19:29:23
Error BASE/1003 Variable does not exist: sudokuLockColumns
Called from __MVGET(0)
Called from UPDATECONTROLPROPERTIES(28480)
Called from SELECTCONTROL(4247)
Called from PROPERTYEDIT(7813)
Called from (b)MAIN(943)
Called from EVENTS(2742)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4884)
Called from DOMETHOD(7352)
Called from _OPEN(25747)
Called from EDITFILE(29706)
Called from (b)MAIN(804)
Called from _DOCONTROLEVENTPROCEDURE(5200)
Called from EVENTS(1619)
Called from _ACTIVATEWINDOW(4810)
Called from MAIN(984)
sudoku_IDE.zip
(2.03 KiB) Downloaded 292 times
Re: Grid rename via IDE
Czarny_Pijar wrote:My efforts to re-create rathinagiri's sudoku in the IDE enviroment has been stopped suddenly when I tried to rename from 'Grid_1' to 'sudoku' in the 'Object Inspector' window.
HMG Errorlog File
I'll check it ASAP.
Thanks for reporting
I've fixed and attached to this message.
ide2010.04.25.rar
(757.09 KiB) Downloaded 407 times
Thanks a lot Roberto :)
Best Regards
