It's pretty easyrathinagiri wrote:I can't figure out.
I had an epiphany (another boring story :)
- Roberto Lopez
- HMG Founder
Re: I had an epiphany (another boring story :)
- Roberto Lopez
- HMG Founder
I'll check it.fchirico wrote:Perdón, cuando dije FLECHA IZQUIERDA, quise decir FLECHA DERECHA.fchirico wrote:Roberto Lopez wrote:Well....
.....En el ejemplo si voy hasta la columna 6 y hago click en la columna 1 ( la que está LOCKEADA ) para editarla, al confirmar la edición con el ENTER y luego presiono la FLECHA IZQUIERDA para volver a la columna 6, debo apretar tantas veces la FLECHA IZQUIERDA como celdas tengo "ocultas", lo ideal sería que valla a la columna 6 de inmediato........
Sorry, when I said LEFT ARROW, RIGHT ARROW meant.
Thanks for reporting.
- Roberto Lopez
- HMG Founder
I've was a FoxPro programmer. In FoxPro, FREEZE has a different meaning. This is the reason my choice was LockColumns.esgici wrote:Yes, everything is OK for me too
Tested, LOCKCOLUMNS with values other than 1 (even less than 1 and greater than column counts !), and applied some previous GRID samples; no problem seen![]()
By the way, this was LOCK or FREEZE ? It seem to me in old days ( happy dBase and Clipper days) these was two separate process.
Now, we need waiting test results by Marek
Best regards and hearty thanks Roberto
- Roberto Lopez
- HMG Founder
Oh nooo... do HMG is relaxing for meesgici wrote:Your are working for us even in your relax time
- esgici
Your choice and implementation is exactly compatible with dBase tooRoberto Lopez wrote: ...
"Boring story" is the mine, your work is excellent as always
Best regards and thanks again
Viva INTERNATIONAL HMG
Are you by any way deleting and inserting the whole column?
- Roberto Lopez
- HMG Founder
Nop!rathinagiri wrote:Are you by any way deleting and inserting the whole column?
A LOT EASIER
Roberto,
first of all, thanks.
When you edit a cell and finish the edition pressing Enter the cursor doesn't pass to next cell (like in sample GRID.37), the cursor still in the same cell.
BTW, Is posibble to have similar key for fast movements like Excel (it could be friendly with users):
CRTL+HOME :=Firts Cell
CRTL+END :=Last Cell (Last row and Column)
CRTL+LEFT :=First Cell of current row
CRTL+RIGHT :=Last Cell of current row
CRTL+UP := First Cell of current column
CRTL+DOWN := Lastt Cell of current column
Edit Mode:
Enter: Next Cell
ESC: Finish edit mode and still in the same cell/position
Ed
Edit Mode:
Enter: Next Cell
Ed
- Roberto Lopez
- HMG Founder
I've done that deliberately , because automatic positioning on other column after editing will do automatic scrolling when you have columns locked.Steed wrote:Roberto,
The result appeared to me as confusing for the user.
I'm thinking about an alternative...
Regarding fast movement keys, is an excellent idea (and easy to do too
Thanks!
HI friends,
Thanks Roberto for this nice feature.
My best regards,
My best regards,
