xlmwrtiter for create standalone XLSX files without Excel/Openoffice installed
Source code related resources
juanato
Post by juanato »
Hello.
I would appreciate some help to use xmlwriter in HMG. The default demo included in HMG 3.4.4 cannot be compiled in my project... has some people a better .hbp project to see how ? Thanks.
Re: xlmwrtiter for create standalone XLSX files without Excel/Openoffice installed
juanato wrote: Mon Dec 09, 2019 6:39 pm The default demo included in HMG 3.4.4 cannot be compiled in my project...
can you please tell me which Sample you try ... i can't find "xlmwriter"
Anand
Post by Anand »
I think juanato means this library,
http://libxlsxwriter.github.io/
whose sample is in MiniGUI Extended
c:\MiniGUI\SAMPLES\Advanced\HbXlsxWriter\
Anand
Anand
Also visit for XLSXClass.prg
ok, thx
... seems i need to use Extendet Version to reach next level
jparada
Post by jparada »
Here is the xlsxwriter wrapper for Harbour
https://github.com/riztan/hbxlsxwriter
Javier
About year ago I had a problem with this solution - excel files created with this library had caused excel crashes - I'm wondering if it works ok now, but, I don't have any excel installed in my machines.
Someone can test it?
jparada
Post by jparada »
mol wrote: Wed Dec 11, 2019 9:38 pm About year ago I had a problem with this solution - excel files created with this library had caused excel crashes - I'm wondering if it works ok now, but, I don't have any excel installed in my machines.
Hi Marek,
Which of them?, there are two different libs,
hbxlsxml are wrappers of Fausto at https://github.com/FTrautwein/hbxlsxml
hbxlsxwriter are wrappers of Riztan at https://github.com/riztan/hbxlsxwriter
I can personally confirm that hbxlsxml works correctly (create xml files
fully compatible with Excel), I have been deeply this lib making reports.
On the other hand, I have not tested much hbxlsxwriter, but I also confirm that it works, in fact it creates real Excel xlsx files and the file sizes are much smaller compared to those created by hbxlsxml.
Javier
apais
Post by apais »
I use Fausto's library in Alaska xbase++ without problems since a couple years on excel, libeoffice, wps office
Not tested on HMG though.
Angel Pais
Georg_BA
Post by Georg_BA »
Hello everyone
Does anyone use XLSX Class - Harbor XLSX library by Srdjan Dragojlovic?
https://groups.google.com/g/harbour-users/c/OtxRtLzf_1E
I would need help setting the column width.
By default, all columns have the same width. Is it possible to change it?
Thanks for help.
Georg
