ComboBox bigger "Button to open" Droplist
is there a Way to get bigger Button in ComboBox to "open" (F4) Droplist.
it is hard to "open" Combobox on Table PC with Touch Screen when Button is "so small"
Re: ComboBox bigger "Button to open" Droplist
Tal vez...
Maybe...
DEFINE COMBOBOX CB_Seleccion
PARENT &cFormPanel.
ROW 25
COL 495
WIDTH 100
HEIGHT 50
ITEMS { }
VALUE 1
FONTNAME "Consolas"
FONTSIZE 20
it does help to use bigger Size / Font but it is still hard to "hit" it on small Touch Screen
now i use F4 and GOTFOCUS Event so Listbox Part will open
p.s. ComboBox is not a good Control for Touch Screen this Way ...
to "scroll" you need to use Scrollbar :(
No he desarrollado para touch,
pero al deslizar el dedo en la lista de elementos
no se mueve hacia arriba o hacia abajo ?
I have not developed for touch,
but when you slide your finger in the item list
not moving up or down ?
HMG Combobox will "mark" Item "under" Cursor
it will scroll when using Wheel
when you "touch" Screen nothing happens in Listbox Part of Combobox
only when DblClick on Touch Screen it does react
franco
Post by franco »
ADDED TO TOPIC JUNE 21 SO YOU CAN SEE WHAT I CHANGED EASILY.
I CHANGED FONT AND ADDED SIZE SEEMS TO WORK OK TOUCH SCREEN. CAN NOT GET SCROLL BAR IN COMBOBOX
I MADE AN ERROR. THE FONT FOR COMBO BOX IS NOT CONTROLLED BY WINDOW DEFINE.
maybe try. font is set at window define.
demo 1 3.4.4.
* HMG ComboBox Demo
* (c) 2002 Roberto Lopez
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;                             //modified
		HEIGHT 200 ;                            //modified
		TITLE 'ComboBox Demo' ;
		MAIN ;
		FONT "courier" SIZE 12
		DEFINE MAIN MENU
			DEFINE POPUP '&Test'
				MENUITEM 'Item Content' ACTION MsgInfo ( Form_1.Combo_1.Item (1) )
			END POPUP
		END MENU
		@ 10,10 COMBOBOX Combo_1 ;
			WIDTH 300 ;                   //modified
			HEIGHT 400 ;                 //modified
			ITEMS { '1 | Uno' , '2 | Dos' , '3 | tres' } ;
			VALUE 1 ;
			ON ENTER MsgInfo ( Str(Form_1.Combo_1.value) ) ;
			FONT 'Courier' SIZE 30                // ADDED
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
All The Best,
Franco
Canada
