DRAG GRID in the same grid
hello, if there is the DRAGITEMS property in a grid?, if there is no way I can move the lines of a grid in position.
Re: DRAG GRID in the same grid
hello, temporary solution would be how could you move a selected row up and down in the grid using buttons
Solo una idea...
Porque no añades una columna en donde pongas el orden en que los quiere:
1
5
3
2
7
9
Y al darle click en el encabezado, ordenas el grid.
Just an idea ...
Why don't you add a column where you put the order in which you want them:
1
5
3
2
7
9
And when you click on the header, you order the grid.
1
5
3
2
7
9
Just an idea ...
1
5
3
2
7
9
hello Andres, I already have the item column but I need to change the order of this column at run time, moving it down or up, and it will be saved with a new order according to the new positioningandyglezl wrote: ↑Fri Jun 18, 2021 3:49 pm Solo una idea...
1
5
3
2
7
9
Just an idea ...
1
5
3
2
7
9
- AUGE_OHR
now move Item 5 behind 2
did you know HMG_DaD* Function
Source of HMG_DaD* Function can be found in HMG IDE Source
http://hmgforum.com/viewtopic.php?p=64177#p64177
this Sample can DragDrop Item from upper GRID to empty GRID Demo Sample also work with TREE and have TREEVIEW_HITTEST
but no ListView_HitTest() (from c:\hmg.3.4.4\SOURCE\c_grid.c )
LVHITTESTINFO Structure include Information "where" you "hit" to "insert" Item
https://docs.microsoft.com/en-us/window ... ittestinfo
Listview and Treeview work "same Way" so i guess it is possible to enhance Demo Sample.
i did it under Xbase++ using Ot4xb with my own native Control but not under HMG (yet)
p.s. you will get in build.log some Warning(s) ...
i do not know how to modify "C" Code in HB_FUNC.PRG to get rid of those Warning(s)
if you have a 2-Dim Array where 2nd Column are for Order : use Decimal to "insert" Item
2
3
4
5
2.0
2.1
3.0
4.0
So fast with VIRTUAL GRID and Move Up and Move Down buttons. Unfortunately, I don't feel up to doing it in Drag And Drop yet - I'm sorry for that.
Local aItems := {}
IF !File ('Items.Array')
StrFile ( Hb_Serialize( {{'Simpson' ,'Homer' ,'555-5555'},;
{'Mulder' ,'Fox' ,'324-6432'},;
{'Smart' ,'Max' ,'432-5892'},;
{'Grillo' ,'Pepe' ,'894-2332'},;
{'Kirk' ,'James' ,'346-9873'},;
{'Barriga' ,'Carlos' ,'394-9654'},;
{'Flanders' ,'Ned' ,'435-3211'},;
{'Smith' ,'John' ,'123-1234'},;
{'Pedemonti','Flavio' ,'000-0000'},;
{'Gomez' ,'Juan' ,'583-4832'},;
{'Fernandez','Raul' ,'321-4332'},;
{'Borges' ,'Javier' ,'326-9430'},;
{'Alvarez' ,'Alberto' ,'543-7898'},;
{'Gonzalez' ,'Ambo' ,'437-8473'},;
{'Batistuta','Gol' ,'485-2843'},;
{'Vinazzi' ,'Amigo' ,'394-5983'},;
{'Pedemonti','Flavio' ,'534-7984'},;
{'Samarbide','Armando' ,'854-7873'},;
{'Pradon' ,'Alejandra','???-????'},;
{'Reyes','Monica','432-5836'}} ), 'Items.Array' )
WIDTH 550 ;
HEIGHT 400 ;
TITLE 'Hello World!' ;
DEFINE MAIN MENU
DEFINE POPUP 'File'
MENUITEM 'Load Items' ACTION ( aItems:= hb_DeSerialize ( FileStr ( 'Items.Array' ) ), Form_1.Grid_1.ItemCount := Len ( aItems ), Form_1.Grid_1.Refresh, MsgInfo ("Items Loaded"))
MENUITEM 'Save Items' ACTION ( StrFile ( Hb_Serialize( aItems ), 'Items.Array' ), MsgInfo ("Items Saved"))
MENUITEM 'Clear Items' ACTION ( aItems:= {}, Form_1.Grid_1.ItemCount := Len ( aItems ), Form_1.Grid_1.Refresh)
END POPUP
END MENU
@ 10,10 GRID Grid_1 ;
WIDTH 400 ;
HEIGHT 330 ;
HEADERS {'Last Name','First Name','Phone'} ;
WIDTHS {140,140,90};
VIRTUAL ;
ITEMCOUNT Len ( aItems ) ;
ON QUERYDATA QueryTest( aItems ) ;
CELLNAVIGATION ;
VALUE { 1, 1 }
@ 10, 440 BUTTON bUp CAPTION "Move Up" ACTION aItems := moveUp( aItems ) WIDTH 80
@ 40, 440 BUTTON bDown CAPTION "Move Down" ACTION aItems := moveDown( aItems ) WIDTH 80
CENTER WINDOW Form_1
Procedure QueryTest( aItems )
Local i := This.QueryRowIndex
Local j := This.QueryColIndex
This.QueryData := aItems [ i ] [ j ]
Function moveUp( aItems )
Local nPos := Form_1.Grid_1.Value [ 1 ]
Local nCol := Form_1.Grid_1.Value [ 2 ]
Local aRow
IF Len ( aItems ) > 0 .AND. nPos > 1
aRow := aItems [ nPos ]
hb_ADel( aItems, nPos, .T. )
hb_AIns( aItems, nPos - 1, aRow, .T. )
Form_1.Grid_1.Value := { nPos - 1, nCol }
RETURN aItems
Function moveDown( aItems )
Local aRow
IF Len ( aItems ) > 0 .AND. nPos < Len ( aItems )
hb_AIns( aItems, nPos + 1, aRow, .T. )
Form_1.Grid_1.Value := { nPos + 1, nCol }
RETURN aItems
edk wrote: ↑Fri Jun 18, 2021 10:02 pmSo fast with VIRTUAL GRID and Move Up and Move Down buttons. Unfortunately, I don't feel up to doing it in Drag And Drop yet - I'm sorry for that.Code: Select all
#include "hmg.ch" Function Main Local aItems := {} IF !File ('Items.Array') StrFile ( Hb_Serialize( {{'Simpson' ,'Homer' ,'555-5555'},; {'Mulder' ,'Fox' ,'324-6432'},; {'Smart' ,'Max' ,'432-5892'},; {'Grillo' ,'Pepe' ,'894-2332'},; {'Kirk' ,'James' ,'346-9873'},; {'Barriga' ,'Carlos' ,'394-9654'},; {'Flanders' ,'Ned' ,'435-3211'},; {'Smith' ,'John' ,'123-1234'},; {'Pedemonti','Flavio' ,'000-0000'},; {'Gomez' ,'Juan' ,'583-4832'},; {'Fernandez','Raul' ,'321-4332'},; {'Borges' ,'Javier' ,'326-9430'},; {'Alvarez' ,'Alberto' ,'543-7898'},; {'Gonzalez' ,'Ambo' ,'437-8473'},; {'Batistuta','Gol' ,'485-2843'},; {'Vinazzi' ,'Amigo' ,'394-5983'},; {'Pedemonti','Flavio' ,'534-7984'},; {'Samarbide','Armando' ,'854-7873'},; {'Pradon' ,'Alejandra','???-????'},; {'Reyes','Monica','432-5836'}} ), 'Items.Array' ) ENDIF DEFINE WINDOW Form_1 ; AT 0,0 ; WIDTH 550 ; HEIGHT 400 ; TITLE 'Hello World!' ; MAIN DEFINE MAIN MENU DEFINE POPUP 'File' MENUITEM 'Load Items' ACTION ( aItems:= hb_DeSerialize ( FileStr ( 'Items.Array' ) ), Form_1.Grid_1.ItemCount := Len ( aItems ), Form_1.Grid_1.Refresh, MsgInfo ("Items Loaded")) MENUITEM 'Save Items' ACTION ( StrFile ( Hb_Serialize( aItems ), 'Items.Array' ), MsgInfo ("Items Saved")) MENUITEM 'Clear Items' ACTION ( aItems:= {}, Form_1.Grid_1.ItemCount := Len ( aItems ), Form_1.Grid_1.Refresh) END POPUP END MENU @ 10,10 GRID Grid_1 ; WIDTH 400 ; HEIGHT 330 ; HEADERS {'Last Name','First Name','Phone'} ; WIDTHS {140,140,90}; VIRTUAL ; ITEMCOUNT Len ( aItems ) ; ON QUERYDATA QueryTest( aItems ) ; CELLNAVIGATION ; VALUE { 1, 1 } @ 10, 440 BUTTON bUp CAPTION "Move Up" ACTION aItems := moveUp( aItems ) WIDTH 80 @ 40, 440 BUTTON bDown CAPTION "Move Down" ACTION aItems := moveDown( aItems ) WIDTH 80 END WINDOW CENTER WINDOW Form_1 ACTIVATE WINDOW Form_1 Return Procedure QueryTest( aItems ) Local i := This.QueryRowIndex Local j := This.QueryColIndex This.QueryData := aItems [ i ] [ j ] Return Function moveUp( aItems ) Local nPos := Form_1.Grid_1.Value [ 1 ] Local nCol := Form_1.Grid_1.Value [ 2 ] Local aRow IF Len ( aItems ) > 0 .AND. nPos > 1 aRow := aItems [ nPos ] hb_ADel( aItems, nPos, .T. ) hb_AIns( aItems, nPos - 1, aRow, .T. ) Form_1.Grid_1.Refresh Form_1.Grid_1.Value := { nPos - 1, nCol } ENDIF RETURN aItems Function moveDown( aItems ) Local nPos := Form_1.Grid_1.Value [ 1 ] Local nCol := Form_1.Grid_1.Value [ 2 ] Local aRow IF Len ( aItems ) > 0 .AND. nPos < Len ( aItems ) aRow := aItems [ nPos ] hb_ADel( aItems, nPos, .T. ) hb_AIns( aItems, nPos + 1, aRow, .T. ) Form_1.Grid_1.Refresh Form_1.Grid_1.Value := { nPos + 1, nCol } ENDIF RETURN aItems
Edk thank you that's exactly what I needed right now
hello edk, I need to make this move without using virtual grid because I already loaded the normal grid with the command ADD ITEM aCol TO Grid_2 OF Form_Novo_projeto
For i:= 1 To oQuery:LastRec()
aCol[1] := cPrioridade
aCol[2] := cStatus
aCol[3] := Alltrim(STR(i))
aCol[4] := Alltrim(oRow:fieldGet(2) )
aCol[5] := Alltrim(oRow:fieldGet(3) )
aCol[6] := Alltrim(oRow:fieldGet(7) )
aCol[7] := PGENERIC( 1 , "descricao", "fabricantes" , "codigo" , Alltrim(oRow:fieldGet(5)) )
aCol[8] := Alltrim(oRow:fieldGet(4) )
aCol[9] := Alltrim(str(oRow:fieldGet(15) ) )
aCol[10] := Alltrim(str(oRow:fieldGet(16) ) )
aCol[11] := Alltrim(str(oRow:fieldGet(17) ) )
aCol[12] := DtoC((oRow:fieldGet(10) ))
aCol[13] := DtoC((oRow:fieldGet(11) ))
aCol[14] := DtoC((oRow:fieldGet(12) ))
aCol[15] := DtoC((oRow:fieldGet(13) ))
aCol[16] := DtoC((oRow:fieldGet(14) ))
aCol[17] := Alltrim(oRow:fieldGet(22) )
aCol[18] := Alltrim(STR(oRow:fieldGet(28)))
aCol[19] := PGENERIC( 1 , "nome", "fornecedores" , "codigo" , Alltrim(oRow:fieldGet(6)) )
aCol[20] := Alltrim(str(oRow:fieldGet(18) ) )
aCol[21] := Alltrim(STR(oRow:fieldGet(21)) )
aCol[22] := Alltrim(STR(oRow:fieldGet(20)))
aCol[23] := Alltrim(oRow:fieldGet(22))
aCol[24] := Alltrim(STR(oRow:fieldGet(1)))
oQuery:Skip(1)
Next
IMHO regular GRID has limited ability to manipulate the order of items. You would have to remove all items and add again in a different order.
Better to use virtual and run directly on an array.
For virtual grid just change: to
oQuery:Skip(1)
Next
AADD (aItems, aCol)
oQuery:Skip(1)
Next
Form_Novo_projeto.Grid_2.ItemCount := Len ( aItems )
Form_Novo_projeto.Grid_2.Refresh
