Post
by AUGE_OHR »
i do have a CONTEXT MENU and 3 MENUITEM with ACTION
is it possible to activate MENUITEM from a Function
// i want to activate 2nd MENUITEM
DoMethod("Form_1", "MYMENU", 2, "ACTION" )
Post
by andyglezl »
Y porque no directamente...
And why not directly ...
DEFINE CONTROL CONTEXT MENU LB_ColFillArea OF Win_Ctrls
MENUITEM "item 1" ACTION Action1fromMyMenu()
MENUITEM "item 2" ACTION Action2fromMyMenu()
Action2fromMyMenu()
Post
by AUGE_OHR »
to call MENUITEM direct was just a Idea.
i have to paas some Parameter but i can not use Parameter at
CREATE EVENT PROCNAME ImageWheelEvent(Parameter ...)
while MENUITEM have those Parameter i thought ...
Post
by Rathinagiri »
Why not this?
Create Event ProcName ImageWheelEvent1()
Function ImageWheelEvent1()
ImageWheelEvent( Parameter ... )
Post
by AUGE_OHR »
Rathinagiri wrote: ↑Sun Jun 06, 2021 6:59 pm
hm ... where do i get "Parameter" from
Post
by Rathinagiri »
Can't you use the same parameter from the menuitem?
I don't understand the context. Please post a small working sample. Let me try.
Post
by AUGE_OHR »
Rathinagiri wrote: ↑Mon Jun 07, 2021 1:30 am
LOCAL a,b,c,d
Create Event ProcName ImageWheelEvent(a,b,c,d)
Function ImageWheelEvent(a,b,c,d)
Error BASE/1003 Variable does not exist a
Post
by andyglezl »
PUBLIC a,b,c,d
Create Event ProcName ImageWheelEvent( a,b,c,d) HWND ImageEdit.HANDLE STOREINDEX nIndex
work...
Post
by AUGE_OHR »
hi,,
thx for help
andyglezl wrote: ↑Mon Jun 07, 2021 5:02 pm
PUBLIC a,b,c,d
YES it work that Way ...
work...
but if i use PUBLIC i do not need Parameter
i try to avoid PUBLIC if possible as i have use "too much" when start with Cl*pper where i got LOCAL
i found a Tool called "Summer 93" which does make FUNCTION of each PUBLIC.
FUNCTION ABC(xValue)
STATIC MyValue := 0
IF PCOUNT() > 0
MyValue := xValue
RETURN MyValue
this Way i got rid of PUBLIC (which need limited DGROUP Space)
franco
Post
by franco »
You could use PRIVATE which I think gets released when calling function is released.
PRIVATE a,b,c,d
All The Best,
Franco
Canada
