how to "test" if ACTIVEX was create ?
i can create a ACTIVEX ... even when PROGID does not exist :o
this Sample, using Windows Media Player, should work while it is default in Windows OS
when change PROGID it should fail ... but how to "identify Error" (ACTIVEX does not exist) :?:
MEMVAR _HMG_SYSDATA
PROCEDURE Main()
   DEFINE WINDOW Form_1 ;
         AT 0, 0 ;
         WIDTH  800 ;
         HEIGHT 600 ;
         TITLE "Test ActiveX " ;
         ON INIT INIT_WMP() ;
         MAIN
         DEFINE ACTIVEX oxWMP
            PARENT Form_1
            ROW 0
            COL 0
            WIDTH  800
            HEIGHT 600
            PROGID "WMPlayer.OCX.7"  // this PROGID work ... change it to "DUMMY.OCX"
         END ACTIVEX
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
PROCEDURE INIT_WMP()
LOCAL oWMP
   oWMP := GetProperty("Form_1","oxWMP")
   msgdebug("Type "+ VALTYPE(oWMP))  // -> "U"
   oWMP := Form_1.oxWMP.OBJECT
   msgdebug("Type "+ VALTYPE(oWMP))  // -> "O"
   msgdebug("Version " + oWMP:versionInfo) // will crash if wrong PROGID
Re: how to "test" if ACTIVEX was create ?
AUGE_OHR wrote: Mon May 17, 2021 5:01 am hi,
Hi Jimmy,
Please try the following updated sample:
PROCEDURE Main()
         AT 0, 0 ;
         WIDTH  800 ;
         HEIGHT 600 ;
         MAIN
            PARENT Form_1
            ROW 0
            COL 0
            WIDTH  800
            HEIGHT 600
            PROGID "DUMMY" //"WMPlayer.OCX.7"  // this PROGID work ... change it to "DUMMY.OCX"
         END ACTIVEX
LOCAL oWMP, cVersionInfo
   BEGIN SEQUENCE WITH __BreakBlock()
      cVersionInfo := oWMP:versionInfo
      msgdebug("Version " + cVersionInfo)
   RECOVER
      msgSTOP("Wrong PROGID!")
   END
HTH :idea:
thx for Answer.
is
STATIC function __BreakBlock()
   RETURN { | oErr | Break( oErr ) }
the same as
   bOldError := ERRORBLOCK( { | e | BREAK( e ) } )
   BEGIN SEQUENCE
   RECOVER USING oError
      ERRORBLOCK( bOldError )
my Problem are that on 1 PC (!) my 64 Bit App fail ... Yes it is 64 Bit Windows OS
STATIC PROCEDURE INIT_WMP()
LOCAL bOldError, oError
      BEGIN SEQUENCE
         o__WMP := TWMP() :New( Form_1.oxWMP.Object )
METHOD New( oActiveX ) CLASS TWMP
   IF HB_ISOBJECT( oActiveX )
      BEGIN SEQUENCE
         ::oWMP := oActiveX
it DID "pass" both but when call
   METHOD GetVersion() INLINE ::oWMP:versionInfo
it does crash on "that" PC with 64 Bit ... it work when use 32 Bit ...
i have run "SFC /Scannow" and did a "inplace Upgrade" to get a "fresh" Version but still the same.
so what can i do "more" :idea:
p.s. in MiniGUI Extendet Version i found EnablePermissions() ... what are this for :?:
