ActiveX IPICTURE ?
- AUGE_OHR
ActiveX IPICTURE ?
VLC have Method "takeSnapSho"t where i get a IPICTURE Question : how to show/save ActiveX IPICTURE
Re: ActiveX IPICTURE ?
cImage_path = "E:\frames\image.jpg"
lResult = oVlc:TakeSnapshot(media, 0, cImage_savepath, 0, 0)
Hola Jimmy : prepare una libreria a partir del LibVLC https://wiki.videolan.org/LibVLC/
The libVLC (VLC SDK) media framework can be embedded into an application to get multimedia capabilities.
Since VLC is based on libVLC
- AUGE_OHR
hi
thx for Advice
is it so easy if know howdanielmaximiliano wrote: ↑Thu Apr 29, 2021 1:07 pmCode: Select all
cImage_path = "E:\frames\image.jpg" lResult = oVlc:TakeSnapshot(media, 0, cImage_savepath, 0, 0)
thx for Advice
- AUGE_OHR
Ahh ... use VLC "direct" ... have to look for that Way, thxdanielmaximiliano wrote: ↑Thu Apr 29, 2021 6:26 pmThe libVLC (VLC SDK) media framework can be embedded into an application to get multimedia capabilities.
- AUGE_OHR
i have test Method TakeSnapshot() of VLC and found out that it have no Parameter
it will create "RAWVLC*.BMP" which "is" a "PNG" File.
Problem :
"RAWVLC*.BMP" seems to be "locked" so i have to "wait" to open/delete File after import into Memo / BLOB
lResult := ::oVideo:TakeSnapshot()
Problem :
Hola Jimmy , en todos los lenguajes de programacion el metodo TakeSnapShot tiene parametros..AUGE_OHR wrote: ↑Thu May 06, 2021 5:42 pm hi,
i have test Method TakeSnapshot() of VLC and found out that it have no ParameterCode: Select all
https://forum.videolan.org/viewtopic.php?t=111824
- in Android test java file
new Thread(new Runnable() {
public void run() {
boolean result = mLibVLC.takeSnapshot(0, "/sdcard/Android/data/com.ebs.android/capture.png", 640, 480);
if(result)
Log.d("EBSSAMPLE", "snapshot success");
- AUGE_OHR
i have try different Version but when add a Parameter into Method TakeSnapShot() ActiveX crash.
it "seems" only to work without any Parameter.
would be interesting how to use different Device e.b. WebCAM instead of "File:///"
as my "own" Snapshot Function (Print-Screen) work also for VLC i do not need "internal" VLC Function.
i "think" ActiveX is limited so i need "native" Version to use what VLC have.danielmaximiliano wrote: ↑Thu May 06, 2021 7:24 pm Hola Jimmy , en todos los lenguajes de programacion el metodo TakeSnapShot tiene parametros..
i will have a look how "native" Version work.danielmaximiliano wrote: ↑Thu May 06, 2021 7:24 pm https://forum.videolan.org/viewtopic.php?t=111824
Jimmy : LibVLC es open source, puede usted mirar aqui https://videolan.videolan.me/vlc/group__libvlc.html
sus funciones aqui https://videolan.videolan.me/vlc/group_ ... video.html
sobre TakeSnapshot aqui https://videolan.videolan.me/vlc/group_ ... b2d5a59143
acerca sobre TakeSnapShot
In order to do this we will use video_take_snapshot method with the MediaPlayer object
Syntax : media_player.video_take_snapshot(n, location, width, height)
Argument : It takes video output number, folder location and width and height of screenshot as argument
Return : It returns 0 on success, -1 if the video was not found
Si, estoy mirando la Wiki https://wiki.videolan.org/ActiveX/
